testing aero. of a caravan
Ran across these on You-Tube:
https://www.youtube.com/watch?v=karGqjCZOV8 |
Thats a very dirty wake. Must be room for huge improvement
huge
Would a kammback help if boat tail is too long
What about that "part 2" video with the topper? Is that better or worse?
https://youtu.be/sweZltfD-no |
I'd go with different. They missed a bet not putting the two videos one above the other and matched in speed.
It's interesting to watch the lines approach from the left. There's some initial noise that damps down to straight lines, but they aren't erased so it obscures the initial approach. There appears to be turbulence building up ahead of the rooftop container, it might be caused by the airgap between the topper and roof. The topper seems to create a locked in rolling vortex ahead of the trailer, similar to a half-tonneau cover on a pickup. What do you think about the area above and behind the trailer? With the container the disturbed air rises higher, even out of the rendered flow lines, but it looked somehow more orderly to me. |
kammback
Here you can see how Koenig-Kamm experimented with different lengths of this K-form at the FKFS,next door to Daimler-Benz in Stuttgart. http://i1271.photobucket.com/albums/...titled5_17.jpg |
topper
I don't think the streamline filaments would behave the way they're depicted. |
above and behind
Here are some comparison images http://i1271.photobucket.com/albums/...titled10_9.jpg http://i1271.photobucket.com/albums/...ntitled8_9.jpg http://i1271.photobucket.com/albums/...head2/2239.jpg http://i1271.photobucket.com/albums/...head2/2234.jpg http://i1271.photobucket.com/albums/...head2/2226.jpg http://i1271.photobucket.com/albums/...ohead2/227.jpg http://i1271.photobucket.com/albums/...d2/06-2835.jpg http://i1271.photobucket.com/albums/...Untitled-5.jpg http://i1271.photobucket.com/albums/...titled8_10.jpg http://i1271.photobucket.com/albums/...itled10_10.jpg |
After watching it, YouTube offered up this gem:
https://www.youtube.com/watch?v=0577mRifVfI Improved aero over most trailers, but the really interesting thing is the hydraulic lowering by rotating the entire suspension assembly. |
That's actually kinda neat. The lowrider and extreme camber crowds will see the utility. Lay frame.
http://i1271.photobucket.com/albums/...head2/2239.jpg This is quite literally the proverbial 'blue smoke and mirrors', but what it puts me in mind of is polarized light. If you have a material that varies in thickness between two polarizing filters at an angle to each other white light gets bent into various colors. Water might work better than air. Even if the wavelength only varies by a few angstroms a high resolution capture with false color imaging should allow you to view a run from some narrow angle. Circular water tunnel and orbiting polarizer. Filters displaceable in the longitudinal direction for 3/4 front and rear views. |
https://www.youtube.com/watch?v=D43tP4PtPLU |
This Wiki illustration shows *how* this sonic (Von Karman vortex) nutation occurs: https://upload.wikimedia.org/wikiped...-animation.gif from this Wiki page: https://en.wikipedia.org/wiki/K%C3%A..._vortex_street https://upload.wikimedia.org/math/7/...48ee53b56a.png where "ƒ·d/V" is called the "Strouhal Number" and: f = vortex shedding frequency d = diameter of cylinder V = flow velocity A published UK workshop presentation: http://wwwf.imperial.ac.uk/ssherw/bb..._Meneghini.pdf ...and a NASA paper: https://info.aiaa.org/tac/ASG/FDTC/D...-1218-1989.pdf |
listening
In the movie,"Who Killed the Electric Car," there is a brief sequence shot inside the GM wind tunnel,of Dr.Paul MacCready 'listening' to the boundary layer of the GM/AeroVironment 'Sunraycer' electric race car.
Paul was using the static pressure tap of a Pitot tube with a stethoscope to hear the 'rustle' when the LBL transitioned over to TBL.Clever! Perhaps unidirectional microphones can discern the same thing.Cool!:thumbup: |
The Boeing wind tunnel has 100 microphones (on at least one traveling pickup) so they can create a virtual three-dimensional model of the sound waves. They demonstrate that the areas of concern are the landing gear and control surfaces, especially in the gaps that open up when a flap or elevron articulates.
