EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   THink this will be beneficial (Extending kammback) (https://ecomodder.com/forum/showthread.php/think-will-beneficial-extending-kammback-29446.html)
paintme205 07-09-2014 10:05 PM
This is my previous kammback that I had. It did help but I decided to lengthen it nearly 10 inches, raise it a degree or two and also add the side panel.
Worthwhile or no?
Old.
http://i772.photobucket.com/albums/y...ackredone.jpeg
New. I did enclose the drivers side as well.
http://i772.photobucket.com/albums/y...ieceadded.jpeg
Without doing a full boattail I don't think I can do much more to the car. Maybe some rear wheel covers. Any other ideas. I use the hatch all the time so I can't justify a boat tail.
Rishar 07-09-2014 10:10 PM
Looks nice! Don't know how much it'll help.
spacemanspif 07-09-2014 10:24 PM
extend the sides all the way down to the bumper with clear plexi glass or lexan. Just like ecoTex's dad's VX
http://ecomodder.com/forum/showthrea...avy-28815.html
aerohead 07-10-2014 03:07 PM
gain
The upper elongation moves the upper separation point back along with deceleration and pressure recovery.That's good.
The base pressure of the wake is however decided by the pressure at the taillights and below,which is well below that of the upper body.The low pressure below is adulterating the higher pressure up top,to compromise the performance of the existing elongatioon.
The only way to really cut drag is to enclose the entire perimeter,like a plan-tapered box-cavity which,combined with the upper mods, move the entire separation point rearwards with plan taper.
Something like a swing-away spare tire holder as used on Nissan SUVs,mounted to the bumper,would allow the lower portion to swing sideways for hatch operation.
paintme205 07-10-2014 05:45 PM
If I understand correctly, enclosing around the taillights with lexan then would be beneficial? More beneficial would be extended bumper and taillight area so it all matches in length?
Hopefully that makes sense.
freebeard 07-10-2014 11:00 PM
What does it look like underneath?
http://ecomodder.com/forum/member-fr...edefyuzer1.jpg
aerohead 07-11-2014 04:26 PM
understand
Yes,exactly.
The Lexan would be cheap 'n dirty way and would perform about equal to actually extending everything else back even with your existing extension.
Motorists would know exactly what you were up to with a clear line of sight to your taillights.
BamZipPow is doing this right now with his boat tail-based on a 1-wheel trailer.
paintme205 07-11-2014 05:50 PM
Originally Posted by freebeard (Post 434773)
I have a smooth belly pan for 1/3 of the front of the car. I need to find some cheap coroplast or sheet metal to finish the back half. I prefer sheet metal (obviously) due to it's durability. I actually take this little car off road almost weekly getting to some relaxation spots.
Aerohead,
Thanks man. I will be getting some plastic this weekend.
aerohead 07-11-2014 05:55 PM
plastic
You should be in 50-mpg territory real soon!:D
freebeard 07-11-2014 07:32 PM
PolyMetal. Dirt track racers use it for their big wings. Stiff as 5/8" ply with 1/10th the weight.
It's enameled aluminum skins on 3mm sheet plastic.
http://t0.gstatic.com/images?q=tbn:A...G6ieBb0RXBkCVg
