06-17-2015, 01:23 PM
FS 2001 Insight manual trans
Who wants my 2001 Honda Insight? 230,000 miles. IMA battery and controllers replaced by Honda at 95,000 mi;es and still going strong. Idles rough but starts fine and runs (injectors? compression?) Lacks power on highway and catalyst efficiency codes (clogged cat?). Trans synchros worn. Left rear e brake hangs up sometimes. Oil leak. Coolant leak but never over heated. Body is still very good. Sell the parts and have a good donor for an EV conversion.
06-17-2015, 01:46 PM
This should be interesting.
regards
mech
06-17-2015, 02:40 PM
Interested! Too far away though.
06-17-2015, 03:41 PM
Is it the one that hasn't had a fuel log update since 2011? Has it been sitting since then?
How much are you asking? Sounds like a thousand buck fixer upper from the description.
06-17-2015, 04:03 PM
I drove it regularly every winter but just didn't log the fuel economy since I was only getting 58 mpgUS. I'm at $1500 firm. I can get $700 just for the battery.
06-17-2015, 04:36 PM
Nahhhh, that's too much for what it's needing.
I'm pretty interested in finding out who is paying 700 bucks for a used 135K mile IMA battery from an individual, though! That would be a good back-up plan in case I wreck mine. I'd say you could part out the electronics, headlights, doors, wheels, wheel covers, etc . . . and make more than the 1500 bucks though, if you have time on your hands
Do you have any pics of it, btw?
06-17-2015, 05:06 PM
Yes, if you can get that for the battery sell it for $700 then sell the car for $1000 with a battery bypass.
06-17-2015, 08:56 PM
Hydrogen > EV
How much do you want for it? I'm in Ohio, and would pull parts to get one road worthy and just drive it until the end.
06-17-2015, 10:15 PM
#9 (permalink)
I'm going to hold out for $1,500. I still drive it with the worn out synchros but you have to double clutch. The engine is the issue with a miss at idle, lacks power on the highway, oil leak, coolant leak, evap light. Never been wrecked aside from a bop in the rear bumper and a scratch in front of the left rear wheel that hasn't changed in the 9 years I have owned it.
12-21-2015, 07:18 PM
#10 (permalink)
Was going to fix it and keep driving it but didn't find the time so I still want to sell my 2001 Insight.
