For those with a Corolla
Others who have a Corolla around the same vintage as mine might find this interesting. 1ZZ-FE engine info.
Looks interesting, do you know where they got it from? It'd be cool to see something like that for Toyota's other engines as well.
chuckm -
I like it. If it had a BSFC map, that would have been the bee's knees. CarloSW2 |
...anybody found similar for the next-gen 2ZR-FE engine, ie: HP, torque and BSFC map?
It could be 3D, but iono what the third variable would be. A BSFC map has more than one range value for each domain value, an onion map more or less, not just a curve.
roflwaffle -
X=RPM Y=torque (or power or load?) Z=fuel consumption This is an XY plot of different engines based on : X=engine displacement (that does look like RPM) Y=torque CarloSW2 |
