Throttle locking the cruise control?
I'm wondering if it would be possible to lock the Throttle cable into a fixed posistion by adding a cut-out switch to the CC control lines??
1. Get up to speed and engage CC. 2. Flip switch and turn off signals to actuator. My first guess would be to add a DPST toggle switch to Open the BRN/BLK & BRN/WHT (Inputs B and C) lines going to the CC Actuator (lower right side of pic). If there is some kind of mechanical 'Hold' function in the actuator, then it should lock up without any new control signals to enable it.??? Or, am I way off base?? Comments please. http://i46.photobucket.com/albums/f1...ger/CRV/cc.jpg |
I have been wanting to do this but nobody has a diagram for my car.
I think simply putting a switch or cutting the VSS lines would do the job since the cruise control would not get any speed information and maintain the throttle position where you left it.. ?? |
Hi,
There was a thread on this very same topic, fairly recently. |
I'll bet CC box would see no pulses as less-then 1 RPM and drop off line. I did think about using a 555 clock signal to replace the VSS input. Since it would be unchanging, it would fool the SS controller into thinking the speed was remaining very constant. Therefore, it wouldn't send any correction signals.. :p But, there could be problems with that idea if the CC box got the idea to increase speed.. AND THERE WAS NO REAL FEEDBACK!! LOL! The gismo just might redline your engine in no time.. --- It might be safer to lock the cable in posistion and switch-out the signals trying to speed up or slow down the ICE.. I think the question is, how does the actuator hold the cable in posistion?? I just don't know enough about vacuum actuators.. |
The poster was using a Ford MAP? that would vary an output frequency as the vacuum pressure(MPG) changed.. I was thinking maybe something like a Frequency Switch Frequency Switch: 14447 AutoSpeed could be used with that Ford part, to detect when MPG was poor and back off on the CC by putting a few pluses on the Set/DECEL I/O line.. All we would need is someone to program a little controller chip to apply up and down pulses to the CC.. (1 MPH increments). :D Should not be hard to make a device that would send a Down(decel) pulse once ever 2 or 5 seconds while the MPG is bad.. Once you hit the top of the hill,(And MPG was good) the device could send Up pulses to get the car back to speed.. The firmware would have to keep track of the pulse count, in the event of a very short hill. (interrupted the down sequence) :) Making the applied pulse frequency variable, you could set it for long slow hills or short steep ones. The idea would be to knock back the speed on hills to keep the MPG from taking a nose dive and then speed back up at the top, automatically.. Have a dip switch, so you could select how many MPH you wanted slow down.. 4 or 5 MPH drop should be safe if there are no tailgators.. :eek: Heck, while we're dreaming, let's add an I/O line that can be used to switch off the AC solenoid when the MPG goes sour.. :cool: |
Hi,
I think that the upcoming Honda Insight may have some of these features; if my understanding of the Eco mode button is correct. |
They did the AC cut-off mod on aGen1 Honda Insight using a voltage change sensor.
AutoSpeed It just looks at the TPS voltage and turns off the compressor if the peddle is too close to the metal.. ;) That mod could be installed on any car. Depending on the terrain and adjustment, I'll bet you could really save some fuel during the summer season.. I wonder if anyone in the USA sells those neat DIY modules?? That frequency switch (above) looks like exactly what I want for my Weak-Hybrid assist controller-motor enable signal. Since I want the assist motor to turn on only above 1,000 RPMs. (Or about 30 MPH). |
