time to replace the catalytic converter
Hi Guys
I have to do some exhaust repairs on my 2000 Saturn SC1 -( manuals trans). It's a great car, 40 mpg in the summer, 35mpg winter. I have to replace the flex joint attached to the down pipe. Unfortunately, It's a welded system. The down pipe, flex joint and cat are all one welded system. So when I do this I figure I will put a new Cat on. Is there a good cat for mileage? Is a performance or hi flow cat worth the money? thanks |
First, Do you live in a place where they check emissions?
They do make high flow cats. They don't always work as well as the stock ones. |
They sell just the flex piece that you can attach to your existing cat, or you can buy the whole setup with a new cat.
It's Walker 53325 I think for the flex piece and $59 at Rockauto.com Then you can use a universal cat for probably under $100 (I see universal Catco converters on Summit Racing for $70) (or $116 for the Walker Ultra cat at Rockauto) They whole assembly is about $170 but only the California version shows in stock there (I think it's fine to use a Cal on a federal, just not the other way around if you lived in CA). If all you need is the flex pipe I would just get it and not replace the converter unless it is actually bad. |
Use a spark plug non fowler to cover the rear oxygen sensor.
It will trick the rear sensor into reading the exhaust leaner than it really is. No check engine light. |
