Tiny House School Bus- Need Ecomodding ideas inside and out
Hello all! Later this year I will be going of to an out of state college college to pursue a degree in agricultural engineering specifically biofuels (hence my user). Since I'm going out of state this is going to severely hurt me lovely wallet for years to come. I've been giving post college life a lot of thought and figured that a school bus converted to a personalized living space would really work for me, because it is cheap, mobile, and efficient (we can use that loosely in terms of moving the bus). I'm reaching out to you all for ideas on how to make the bus both efficient inside and out. I've been to some other sites that deal with tiny house living/school bus conversion, but their intentions aren't always made with the Ecomodding mindset. And from reading on these other sites half the people aren't all that intelligent were as here you have to be to do some of the amazing things people have come up. So that's why I'm posting it here and not on the other sites.
Here is some info on bus aero.
http://ecomodder.com/forum/showthrea...ics-17717.html Note the bulge just behind the leading front edge. On another post that I cant find I believe the bulge alone increased fuel economy 5% at highway speed. Have you thought about heat storage? Just storing hot coolant in a hot water heater for warming the air or heating water for sink or shower use. Solar is another one. Lots of room on the roof for solar. |
I have been thinking about both I'm really fond of a small woodstove for heating both water and the air. My main concern is cooling. I would really like to have a battery pack of 10 (120volt service) and a small rooftop AC. I would use this when evaporative cooling and fans can't do the job. I also planned on having both solar panels and solar water heaters to supply power and hot water in the summer.
Insulation is your friend, both for heating and cooling. Insulation, a light color and keeping the sun off of the bus will help a lot for cooling. You'll need some sort of rack to mount solar equipment on the roof, making it to allow for some sort of fabric sunshade as well will work wonders.
If you have headroom to burn, lowering the insulation and venting the space above it would make the bus roof into a sunshade that wouldn't hurt your aero or need to be disassembled every time you move. |
Where are you going to be?
Evap coolers don't work so well every where. For them to kind of work they need to be used where relative humidity is 50% or less. If you want to use battery power, then 12 batteries in series is not the way to go. Most solar power battery systems use 12, 24 or 48 volts. There are few things that can be powered off 120 volts DC, also 120 volts DC presents an extreme arcing hazard. |
In terms of getting better fuel economy, I would look into some of the things that freight trucks are using:
-Trailer tail -Side skirts -Smooth wheel covers in the front -Adjustable grille block You can see some ideas here: http://ecomodder.com/forum/showthrea...ero-32342.html Definitely insulate. It goes a long way in terms of climate control. |
Why not move to the state where you plan on attending college and work there for a year. Take up residency and then get in state tuition. That should be worth many $$$.
Some students never obtain residency where they attend college, which baffles me, as well as going to another state when there is a perfectly good program near home.
IMHO school busses never had excess headroom.
do you have the school bus now? a rear engine city bus with a low floor and standing head room might have a better frontal area and be a better platform overall.
also if you are thinking of a wood stove i would stick with a diesel engine. sounds like a fun project i look forward to progress updates |
It's not clear how mobile it has to be. If it's mostly going to be standing in one place, I think starting with a bus is a huge compromise.
Far better off building a trailer-able house, that way if you're going out for the day you don't have to take the whole house with you. Leaving 5+ tonnes behind is the best ecomod you can make. You'll likely find a trailer house (or a caravan) far more comfortable to live in. Perhaps not as cool though. |
One advantage of "schoolies" is that they're often retired early, due to regular replacement by the school systems that can be time-based rather than miles- or running condition-based. It's sometimes possible to pick up a mechanically sound retired school bus for as little as $3-5000.
I certainly wouldn't want to drive one around town to do my shopping, but so long as OP doesn't expect to stay at 72F year round in extreme climates, the low entry cost and ability to (relatively) cheaply move the "house" from place to place might work out favorably. |
In my mind, mileage is one of the easier issues. It sounds like your lifestyle will be similar to a fulltime RVer. That means you'll have to deal with issues like where to park it, where to fill/empty the tanks if you don't have full hookups, internet, mail/address, and more. You also have to think of how you'll pay for the conversion and how long it'll take to do. If you have plenty of cash, skills, and time, go for it. If you're looking to finance the whole project, a premade RV would be easier to finance (not sure how easy it would be for an already converted bus). I live full time in a fifth wheel at an RV park, pretty much just stationary. |
Anyway, look at this old Ford F-350 motorhome from Argentina http://3.bp.blogspot.com/-8x3ttWkzqB...o-esquerdo.jpg Sure its aerodynamics are not the best, but might be similar to what you were considering to do. |
I drove school buses for 5.5 years, have driven buses for the National Guard for three more, and am 6'2". I could not stand up straight on some buses, but I am usually fine.
A few seemed designed for pygmies. |
Whatever you do, don't cut up an old VW bus to graft onto the roof. Sailboats have an upper deck that has been evolved for 100s of years to be useful. Stove in the bottom and they get pretty cheap (one would think :))
http://ecomodder.com/forum/member-fr...6-p1010037.jpg I wound up in a 35ft R-license park model trailer. There's a lot to be said for hiring the tow vehicle. That said though, here's my scenario. 60-pass bus with the top half cut off the back emergency door and a wall with full door 4-5 feet ahead. Left rear corner is a (55-gallon drum batch process) composting toilet. Right rear corner is a 7ft tall wood alcohol still. The front bumper is moved forward 2ft and there is a wood chipper clutched off the front of the engine (and an electric winch). There is a 4" round duct from the chipper to a bin on the rear roof to feed the still. |
As a bus driver, I get tired of going up and down those stairs. Is there anything you can do with the space below the floor? I have seen a few small-ish storage boxes.
It just seems like a waste, but I imagine having a curb-level floor (with three-foot wheel wells) is part of the expense of city buses. Hmm... this is currently being auctioned for $1,000, but I am not sure it is optimal... http://cdn.publicsurplus.com/sms/doc...17830/16523815 [Edit] This one runs! :D I have always loved Blue Birds! http://www.publicsurplus.com/sms/auc...ew?auc=1610001 |
Yes, car wreck.
That's not a good example, but a short bus with a wheelchair lift comes with a powered pop-out. Just have an easy chair podule that double-folds with built-in lights and stereo and you'd do most of your living in the pop-out.
I've researched down this path although never followed it, nor do I have ANY rep around ecomodder. I'm aspiring to live on a sailboat and cruise.
What I think is important is how much you plan to drive it. Are you going to be commuting IN IT, or TO IT? communiting in it will probably make a LESHARO a nice choice, either with a dodge 3.3 fwd caravan power train for reliability, or a Renault diesel if you want an anemic engine to become your hobby. I want to recommend the biggest vehicle possible, like say a 35+ft rv, but honestly at that length, you will need LOTS of ground clearance if you ever want to go down dirt/gravel roads at state parks etc. Some of the most awesome places to boondock need a noble vehicle to get to. So if you go big, you're not gonna be able to hug the road, although a boat tail might work, but damn. I would not want to daily drive that sucker. I'd get a short bus, with underfloor storage in the front, which tapers to the back to give ground clearance. Or just buy say an Econoline rv with a 300-I6, or a 460. Although they are big motors, they run efficiently under heavy loads if tuned right. If you research them, ignore the fuel injection's mpg numbers. They are big motors when running stoic afr's, but with either egr or lean burn or both, they can sip fuel at lean ratios without burning up or misfiring. And they are dead reliable and cheap. They also hugely favor torque over power, and are just awesome at low rpm. That, and they never need touched if you change the oil. I doubt you will find a 300-i6 in an rv, but man that would be the best gasoline engine I could think of if you were running 10k pounds or more. Yet were concerned about fuel economy, and daily driving. And were willing to run an megasquirt or something, although they'd probably beat other similar rigs in the gas mileage department, even with EPA legal electronics. I'm not much of a hyper miler, but I LOVE lean burn ford engines. |
