Tire efficiency
I predict a lot of what this guru says will challenge our conventional wisdom:
https://www.youtube.com/watch?v=asEYkpW0vwQ |
Some of these points have been discussed. Tire pressure in relation to the failure caused by different surfaces say rocks and pot holes, for example. The big take away here is optimization. Each "car" location of use and actual usage ( laden be unladen) will determine best pressure. Can you imagine you stop to pick some one up and need to increase you tire pressure by two PSI.
One area of interest was negative space and tire pressure but for most of us we drive various surfaces. This is more relevant to racing than everyday. |
I've only got 5 minutes in, and already, there is a lot wrong by that "expert". Please be aware that they are discussing bicycle tires and those are different than tires that are designed for 4 wheeled vehicles.
But one thing he did get right that needs to be emphasized - what is written on the sidewall has nothing to do with what you ought to run. I'll give a more complete report later - when I have a bit more time . |
I’ve now watched the video. Here are my comments:
First, the video is discussing tires used on racing bicycles. Not only is racing of any sort a peculiar activity, racing bicycles is even more peculiar and has only a small cross application to street cars. Burst pressure: The guy got it backwards. The standard comes first, then the tire is designed to that standard. ETRTO (European Tire and Rim Technical Organization) is one of several tire standardizing organizations in the world. The US counterpart is TRA (The Tire and Rim Association). TRA does NOT publish bicycle tire standards because no one manufactures bicycle tires in the US. While it maybe true that the burst pressure of bicycle tires is about twice the max pressure listed, that is NOT true for car tires. The value is 3 times or more the max pressure. – and, No!, the burst pressure has nothing to do with the max pressure. The burst pressure is dependent on the fatigue strength of the car tire at the rated inflation – and for Standard Load Passenger Car tires, that is 35 psi – and those tires will be labeled with a max pressure of either 35, 44, or 51 psi. Further, tires are NOT labeled with a recommended pressure. They are labeled with either a MAX pressure or a rated pressure (as in Max load XXXX at YY pressure). That is true for ALL tires, regardless of what their intended use is – meaning that even tires for farm tractors will be labeled with either the max or rated pressure, never a recommended pressure. Footprint: Because bicycles lean in turns, the tread surface is rounded. That produces a footprint that is narrow and long – and that is true even when the bike is cornering. By contrast, a car tire doesn’t lean into the corner. It tends to lean more away from the corner, so it is common for cars to start off with negative camber (leans in at the top), which results in a vertical stance (sort of!) when cornering. Also, most cars are designed NOT to be cornered severely, and have to be adjusted if the car is adapted for racing. The fact that the bicycle tire footprint is small and narrow is more affected by the macrotexture of the pavement than car tires. (They used the term “negative space” where I am using the term “macrotexture”). That means that racing bikes can benefit from changes in inflation pressure due to road texture – much more than street cars. The idea that a racing bike should use less inflation pressure on more coarse pavement has merit, but that does not apply to car tires – unless one is racing a car. Further, the racing bike tire needs much less fatigue resistance than a street car tire – and higher inflation pressures help fatigue resistance. Latex vs Butyl Rubber: Butyl rubbers are used where air retention is needed. In a car tire, that’s the innerliner – the innermost layer of rubber. In a bicycle tire, using an innerliner adds weight, so some bicycle tires are made of butyl throughout to reduce the weight – BUT – a racing tire (both bicycle and car racing tires) don’t need to hold air pressure for very long – just enough to finish the race – so they may not even use butyl at all. And there you have it! Again, be aware that these guys are discussing tires on racing bicycles. That's quite different than car tires used on the street. |
But I would think this has more to do with the formulation of the compound itself, rather than what type of rubber is being used. That might explain why I didn't find an answer. |
Great link! Thanks Frank. Yes, the trend toward bigger tires and lower pressure on road bicycles is a thing (except in a perfectly smooth velodrome). I have read several recent scientific studies conducted with bicycle tires on a rolling rough surface showing that lower pressures have measurably lower rolling resistance than the max pressure we used to run back in the day. “Gravel” riding and racing is adding to common acceptance of using wider/lower pressure tires.
However, this is primarily a motorized modding site and we should be cautious of using test data developed for road bicycles and applying generalizations to cars. For one thing, cars have sophisticated suspensions. The inflated tire IS the first and most important suspension on a road bicycle. Bike tires are round in cross section, car tires are square where they meet the road and have several steel belts to keep that profile flat in cross section. In my experience I have found higher pressure car tires roll easier and return higher fuel mileage. |
I would add that in the video, they are not discussing rolling resistance, but instead, how "fast" the bicycle tire is. A bicycle for racing typically does not have suspension, and can be "faster" by reducing cyclist fatigue, or by allowing higher speed cornering, or many other factors even if that comes at the expense of a tiny amount of absolute rolling resistance. Maybe I'm confusing the their terminology but from how he was describing his testing procedure it seemed he was looking at lap times, or sprint times.
Although it wasn't stated explicitly, I gather that as some point, rolling resistance improvements diminish sufficiently as to not be "worth" the additional harshness and vibration. |
wisdom
For bicycle tires see "High Tech Cycling" 2nd Ed. (2003) by Edmund R Burke PhD. For automobile tires look for papers from SAE.
rolling resistance
After winning the World Solar Challenge, in 1987, the GM/ Aerovironment team commented that, had they run the entire race on bald tires, their margin of victory due to the superior R-R of the tread-less tires would have way over-shadowed the additional time they would have lost during the race to changing flat tires.The lion's share of R-R had to do with tire squirm of the individual treadblocks. Perhaps at 200-psi, there was virtually zero sidewall flexure, a common source of R-R.
Another reporting, having to do with LRR tires, commented that, the particular tire under discussion, simply lacked 25% of tread depth found in non-LRR tires. Or in other words, one would be paying full-price for a tire which was already 25% worn out. In the mid-1990s, I called a California Saturn dealer to see about purchasing a set of LRR OEM tires for the EV1. The parts manager implored me not to do it. He said that the compound used was so soft that, tread life would be half what a conventional tire would have, and I'd end up purchasing tires twice as often, and would ultimately regret my decision. A book on electric car conversion mentioned that, for every application, there would be an optimum inflation pressure, beyond which,no amount of over-inflation would result in reduced R-R. Exactly what CAR and DRIVER said in another reporting, after doing the experiments at Chrysler Proving Grounds. Race fans will observe that many racing tires are 'slicks' to begin with.:) |
