EcoModder.com
-   Instrumentation (https://ecomodder.com/forum/instrumentation.html)
-   -   tire size (Does ScanGauge have adjustment for different sizes) (https://ecomodder.com/forum/showthread.php/tire-size-does-scangauge-have-adjustment-different-sizes-11462.html)
mcrews 12-15-2009 11:07 AM
Santa is stopping at my place first this year.....as I sit on my porch wanting for my scangaugeII......:D......
I run 255x45x18 tires. the factory size is 245x45x18. I know that the car odometer and mpg gauge is off by about 3% because on my last long roadtrip i used my garmin nuvi gps to track my true mileage.
Does the SGII allow for adjustment for tire size?:confused:
MetroMPG 12-15-2009 11:10 AM
Yup. There's a "speed" offset which you can use to correct for gearing/tire changes or OEM errors in the speedometer/odometer.
FYI, you can view the ScanGauge user manual online:
http://scangauge.com/support/pdfs/SGMan5_1.pdf
(SG2 with Xgauge link)
mcrews 12-15-2009 11:29 AM
thanks Metro!
