EcoModder.com
-   Motorcycles / Scooters (https://ecomodder.com/forum/motorcycles-scooters.html)
-   -   Tire and wheel choice for economical motorcycle (https://ecomodder.com/forum/showthread.php/tire-wheel-choice-economical-motorcycle-33209.html)
Spaghetti Man 12-12-2015 10:44 PM
Hello, I have been thinking about what is the most fuel efficient wheel that has the most economical tires. The wheel will be for sub 200kg (including rider) streamlined recumbent motorcycle (probably electric but that is another thread).
For perspective ($AUD)
CBR125r 2007
Tires $1.00 per 100km (21% total cost) ($230 tire change at 23,000km)
Fuel $3.80 per 100km (79% total cost) (Unleaded 95 $1.40.9 per litre x 2.7L)
Total cost $4.80 per 100km
-- If fuel consumption is lowered to 1L/100km
Tires $1 per 100km (41% total cost)
fuel $1.40.9 per 100km (58% total cost)
Total $2.40.9 per 100km.
As you can see economical tire choice is worth investigating.
Another consideration is that smaller wheels are lighter and fit better inside small fairings allowing for greater steering angles on long wheel base vehicles. If wheel weight was decreased from 18kg to 5kg that has got to be worth some fuel savings (side note wheel weights are very hard to find).
So what are your thoughts on the most fuel efficient tyre/wheels for motorcycle?
Frank Lee 12-12-2015 10:57 PM
Smoothest tread possible and tubeless.
Ryland 12-13-2015 09:04 AM
Look for silica rubber compound, often touring tires.
roosterk0031 12-13-2015 05:51 PM
Your way ahead of me, it took me 100,000+ bike miles to figure it out. If you can't do everything with a bike, own a car, 2's more expensive than 1.
stiletto2 12-14-2015 12:01 AM
I just use my stock scooter wheels and put a car tire on the rear and call it a day :)
Slightly taller than the stock scooter tire for a little leg up ratio wise and the last tire I used went 35,000 miles. (it could have gone several thousand more miles actually) But I changed it to try an even taller tire. Not bad for a tire that lasted 6X as long as a standard tire and cost $23 + $7 for shipping and $20 for installation. It's all I ever use now. It's not for everybody, but it works just fine for me.
cRiPpLe_rOoStEr 12-14-2015 12:21 AM
Not sure if a silica-compound tyre would be so easily available for a small-displacement motorcycle. And a car tyre might become dangerous, as it won't allow you to inclinate while cornering.
CapriRacer 12-14-2015 05:19 AM
A couple of thoughts:
Generally motorcycle and scooter tires have different wheel diameters than car and truck tires. In other words, a 16" tire isn't 16.000", it is different - AND - that diameter is different between cars/trucks and motorcycle/scooters. Directionally, the motorcycle/scooter wheel is larger in diameter and that means that mounting a passenger car tire on a motorcycle wheel has a greatly increased risk of failure during mounting - very dangerous.
stiletto2 12-16-2015 07:49 PM
Yes, and that is partly why I have professionals mount my tires. I don't have the tools to do so and they know the risks of mounting any tire. Never heard from the service people of any difficulty mounting the tires... not that they never did, but they never have said so.
stiletto2 12-16-2015 08:06 PM
That one tire went 35,000 miles with some of those miles banked over scraping hard parts in the twisties. It manages to navigate corners just fine... it just does it differently than a bike tire with its round profile. Bike tire in a lean effectively has a smaller diameter so its like a coffee cup on its side that will follow an arc when rolling. Car tire effectively gets that smaller diameter by compression & flexing of the sidewall along with some of the tread face. Different method, same result; tire follows an arc. Car tire tread does flex and will lie flat on the road surface where it makes contact. It does not ride on a hard immovable, non-pliable edge.
sendler 12-17-2015 08:07 AM
Are you building the frame from scratch or starting with an existing motorcycle? Because you will want to make sure the front end has the correct amount of trail and going with a smaller wheel in the same fork reduces it.
Smaller wheels do package better for a near recumbent/ foot forward design but have less gyro effect for stability.
Wheel/ tire weight only hurts fuel efficiency when you use the brakes.
Using a car tire on the rear of a motorcycle works very well for normal daily riding as proven by thousands of "dark siders" so the smallest of the new eco car tires would be by far the best for the rear. Not sure if any of these guys run a car tire on the front. But my original IRC front tire on my CBR250R is still on at 29,000 miles/ 47,000 km. My rear IRC's last about 24,000 km. The new Michelin Pilot Street tires offer even better life and efficiency.
The easiest project would be to stick with the CBR125R and streamline it at which point you could realistically expect 170 mpgUS, 1.4 L/100km at 100 km/h.
cRiPpLe_rOoStEr 12-23-2015 06:45 AM
You might say whatever you want, I'd not feel comfortable with a car tyre in a motorcycle (unless it has a side-car :D).
sendler 12-23-2015 10:04 AM
How do you know?
1,000s of people have done it and get great performance out of running a car tire on the back of a motorcycle.
jkv357 12-23-2015 10:59 AM
I know of a guy that rides a DL650 Vstrom year 'round, all weather, and uses a car tire on the back in the winter - he loves it.
Personally, I'd never even consider using a car tire on a cycle, but then again, I'd never ride something the size of a Vstrom in 6" of snow either.
As far as a wheel and tire choice for an economical motorcycle, with a bias towards mpg, I would look for a narrow, tall, 17" tire that's not very expensive. There are a ton of choices, with the least expensive being Shinko or Avon.
I bought a set of 16" Avon Viper Strykes for $129 delivered - and they were not outdated overstock either. Not as many options for 16s, but if space is a premium you may want to consider it.
cRiPpLe_rOoStEr 12-23-2015 06:58 PM
Originally Posted by sendler (Post 503022)
How do you know?
Not sure, but I wouldn't feel comfortable with that. Road conditions in my country are different than in America.
Spaghetti Man 01-11-2016 07:27 AM
cbr125r is not an economically viable option for streamlining. The cost of a super efficient streamlined fairing is too costly compared to the amount of money saved on fuel (I have been quoted $5,000 for thermoformed fairing and $1,200 for polystyrene model from which to make a mold of). There is no saving to be made even on 100,000km. The saving of 40% on fuel represents only AUD $1,409 over 100,000km.
I am now exploring super efficient electrathon style vehicle for road travel (even petrol power is too wasteful so I must go electric). These vehicles often use three 20" bmx wheels. The closest to this I can find is for motorcycle are shinko 16" 2.25" tires.
Amazon.com: Shinko SR714 Series Moped Tire - Front/Rear - 2.25-16 , Position: Front/Rear, Tire Ply: 4, Speed Rating: L, Tire Type: Scooter/Moped, Tire Size: 2.25-16, Rim Size: 16 XF87-4550: Automotive
But I cannot find the wheels to go with this tyre. I also don't know what spoked motorcycle wheels weigh so cannot make any concrete decision on the most energy and cost efficient tyres.
This is quite the predicament.
sendler 01-11-2016 07:47 AM
Price has been the problem even with the Vetter streamline kit which is $2,000. Or a Velocar which are $6,000 and then must be electrified.
Best to just get a CBR125R or CBR250R, add a windscreen, tank bag, and an aero trunk and ride it like that at 100 mpgUS.
