"TireBlast TM" Canadian tire verging on unicornian claims
Nitrogen tire inflation
Improves fuel economy Increases tire life Less loss of tire pressure helps prevent uneven tire wear Reduces wheel corrosion Tires run cooler adding tire life Then they sum it all up in a sentence just for "clarity" "Nitrogen tire filling will increase safety and reduce operating costs, while improving the performance of the vehicle." $6.95 per tire. All that for just 6.95? Such a bargain!!1! So how to they get all the old horrible wasteful regular 78% nitrogen air out completely? They must pull a 100% vacuum before right? right? The biggest reason they left out: Avoid those terrible tire fires you have heard so much about. Anyone wish to do the cost/benefit analysis and return period? |
For the same price, and can fill several tires.
Amazon.com: Q Industries HV35 SuperFlow 12-Volt 140 PSI Air Compressor: Automotive And works anywhere you have your car. |
You'd be filling those tires with contaminated nitrogen! Ewwwww! :rolleyes: |
It's dry nitrogen tho, after all on average the air going in to your engine as as much water in it as gasoline as it enters the combustion chamber, so while I question if it's worth the cost, it does have an affect, airplanes use nitrogen in their tires to keep them stable, of course your car is not seeing the changes an airplane sees.
On my last set of tires, I had Radial Tire Store of Sacramento, put nitro in the tires. we had discussed it half way thru my last set and he said that it really needs to be done when the new tire is installed.
I run 44psi w nitro and the psi fluctuates 1psi (the Q45 has psi senors. In the past it was as much as 4psi different hot and cold. The trip that is documented in my signature (third link) was my first ever over 30mpg. I reallt thing the nitro played a role in that. |
Really, though, the slightly increased stability of psi may really be the only material advantage. So if your peak psi is a bit higher without the nitrogen it's not going to be doing you $27.80 plus tax better any time soon.
Gotta love the ill chosen name: TireBlast. Heh heh. "Neglect your tire pressure even more with TireBast!" |
Though you are all missing the major benefit of the nitrogen filling - the green valve stem caps you get!
^^^ they probably make a killing off of that stuff. I can do the same thing by using an air compressor and paying attention to the pressure by checking it weekly.
Every mid 90's Ford Exploder came with these tires from the factory, tireblast indeed.
Boyle? Wasn't he that guy who played Frakensteen? I didn't vote for him, so why is he making laws? |
P*V=n*R*T
P: Pressure V: Volume n: the ammount of molecules of gas R: 8.3144621 (gas constant which is the same for all gasses) T: Temperature The above equation says that no matter the gas for a given change in temperature their will be the same change in pressure given a fixed volume. Quote:
Tell you what I'll sell you a filter that will filter the nitrogen, for $200.
It will pay for itself in less than 10 fillings. disclaimer: depending on atomspheric conditions the concentration will vary |
I have been giving this some thought, and while I agree that it shouldn't really matter what gases are used (air vs N2) to inflate tires, I do think that not enough attention is paid to water.
That's right - water. If humid air is used to inflate tires, then it is possible for the evaporated water to condense out as the tire cools (especially if the tire is initially inflated during periods of warm weather, and then that same tire is used throughout winter). Such condensation will significantly affect tire pressures. That would explain why mcrews saw his tire pressures vary as significantly as they did before he used N2. |
I say fill your tires up with pure carbon monoxide, it would virtually eliminate oxidation issues.
tires blew up....big lawsuit
oh, I know what he meant, I was curious if anybody wasn't sure of what he meant. I know all about the BS/FS tire fiasco
I tried testing nitrogen tire claims back in 2007 since I have access to nitrogen for filling paint ball tanks. A quick trip to ebay and northern tool and a week later I had all the parts assembled to turn a paint ball tank into a fairly dangerous tire filler.
After a month of adding T&P tire data to fuel economy followed by another 5 weeks of nitrogen tire data. The claims: Improves fuel economy Increases tire life Less loss of tire pressure helps prevent uneven tire wear Reduces wheel corrosion Tires run cooler adding tire life My results: "Improves fuel economy" No difference what so ever. "Increases tire life" no way to duplicate in aloted time. But I do nitrogen fill my trailer tires and keep them covered to try and ward off dry rot. "Less loss of tire pressure helps prevent uneven tire wear" Tire pressure varration was the same as with air. Tire leak down with the same as with air as far as I could tell in a standard 32psi tire. "Reduces wheel corrosion" The wheels on my car were 22 years old at the time and there was no corrosion on the inside. Air works fine. "Tires run cooler adding tire life" Seemed to run just as hot as air as tested with my inferred temperature scanner. When I return to newmexico I may try filling tires with Helium. Not expecting a MPG improvemnent but Helium transfers heat at something like 6 time the rate of air or nitrogen. It might help them run cooler. |
*confused* If the gas doesn't matter, why do NASCAR and aircraft use nitrogen?
I saw a unicorn once. Maybe that's why I'm confused... |
Air craft use nitrogen because its dry and they cant have water vapor freezing inside the tire when its -40'F and for fire safty.
Same thing with nascar, but fire safty only. Years ago they used air. On a side note, I read that Lexus rolled cars to the dealerships with tires filled with argon. Reason for doing this? To further dampen road noise. (it seems to work in between window glass panes) I may test this one out, get my girlfriends Iphone and one of those free sound meter apps and do a before and after test. All I have to do is devise a way to get the argon from my welding bottle to the tire. |
Any new car that comes into the dealership that I work at is supposed to get Nitrogen fill for the pre delivery inspection. Do you know what this entails? Remove all four valve stems until the air stops pissing out. Refill with nitrogen and replace valve stem. Add the super cool green cap and BAM! You've just added $100 dollars to the cars value (meaning $100 dollars more in the dealer's pocket). As has been mentioned, nitrogen's use in airplanes and race cars is for the expansion due to water vapor and to prevent tire fires, that is all. |
