Tires and Rims
Hi, I've always wondered this, but I haven't been able to figure it out by pure intuition, so I'm wondering if someone KNOWS the answer.
I have 97 civic ex with 200k miles, runs great... anyway, it has the 15" stock steel wheels. You know how all the kids (im 19, but im not one of THOSE kids) put huge rims on their civics because they think it makes them faster... well I'm about 6 months away from new tires, so I'm wondering if I should get new wheels while I'm at it. So which is lighter: Large rims and thin tires, or small rims and fat tires? What about steel vs. aluminum vs. whatever else? Note: Cost isn't really an issue. For me, FE means fuel efficiency, not fuel economy. |
optimally what you want is a lighter, narower tire rim combination. by going to a larger rim and lower profile tire (assuming the actual OD (outer diameter) remains the same) you achieve better handling due to less side wall flex, now if we also assume that in this process you switch to a narrower tire (from a 195/xx/15 to a 175/xx/15) you will effectively reduce the amount of surface area touching the ground thus reducing rolling resistance.
basicly, what i am saying is 1) you want the lightest possible tire/wheel combination 2) you want the narrowest tire you can get 3)bigger isnt always better, but then again it is not always worse. |
just to clarify, by narrowest i am refering to contact patch, not the side wall, sidewall height mostly affects handling, which if you are driving for efficiency you may rarely see a difference.
also in general magnesium wheels (most expensive) are the lightest, then aluminum (which is what you should buy) and then steel, but this is not always true, i have seen cheap aluminum wheels weigh more than some factory steel wheels. |
Why not small and thin? If some insight wheels will fit on, that's what I'd go for.
I know that a thinner tire is better, but if I get a larger diameter rim do I have to get a wider tire?
by thin and fat i'm referring to the thickness between the rim contact and the outer circumference, not the width. But I'm just asking in general: is large rim/thin tire or small rim/fat tire lighter? by the way, the insight wheels idea is good. I'll look into that also, thanks. |
Shoot for either Insight rims, or HX rims
Well it is not just the weight of the tire/rim you care about. The rotational moment of inertia is even more important, because you have to spin the wheel up to speed and then spin it down to zero rpm when you stop. You want the least amount of weight located at the maximum diameter. This will vary with each model (style) of wheel, no matter if it is steel or aluminium. Also, if you have never driven in a car which came from the factory with "normal" profile tires, and you put on bigger rims with "low" profile tires, you will discover that the ride is punishing. You will feel every crack in the road and every pebble you run over.
So after all that, it boils down to "It Depends" |
Yea well somehow my civic came stock with 15" steel rims. Don't ask me how. Seems to me that the RMI would be smaller if the tire is thinner, hence the reason all the ricers get huge rims and 1 millimeter thick tires. I'm just looking for a small upgrade... if my car looks nicer and I use less gas, its a win-win in my book. Maybe moving up to 16" rims and a slightly thinner tire. Also, it seems like reducing RMI is less effective for highway driving. Are my assumptions above correct?
out of curiosity do you know what size tires you have? if you dont know the size is easy to find, on your car it should look something like this: p195/65/15 but your numbers will vary. in case you dont know this is what that line means: p-pasenger 195-tire width (milimeters) 65-aspect ratio (percentage of tire width equal to sidewall height) 15-wheel size definately look into a smaller set though. |
its dark outside right now, but ill get the info for you in the morning. like I said I'll need new tires soon and I just got an extremely well-paying summer internship, I was thinking of doing a LRR tire/lighter wheel combo.
also, ignore ricer logic, they mostly go for looks. once your OD exceeds your origional OD you are affecting your gear ratio and adding unnecesary mass.if you want a larger rim go with 16's you should still find tires that are the same width as what you have on there now, and in that case you should be able to reduce total wheel and tire weight. but you have to be careful with your wheel selection, as i mentioned earlier, some AL wheels weigh more than steel. -john |
although i should add that *any* change in OD affects your gear ratio, even going smaller
I was thinking of keeping the OD the same, I would just be substituting a larger rim and a thinner tire. So that extra 1" of tire diameter that was there before is now air between the rim spokes. Does anyone follow what I'm saying? I really feel like larger rims and thinner tires would be lighter AND have lower RMI
"ricer logic": oxymoron? |
yep, we're on the same page. but remember get the lightest possible wheels :) (maybe some real racing wheels and not some sears special - those tend to be pretty heavy)
check out summitracing.com they have a decent selection, or tirerack.com, you could easily get a decent set. |
In general, a smaller-diameter wheel with a taller-profile tire is lighter than a larger-diameter wheel with a lower-profile tire. In general, the lower the profile, the stiffer, and therefore heavier construction it will be. Quote:
Search for Flik, Rota, BBS, Gram Lights, and Kosei, all of which are known for light (albeit usually larger) wheels. Also, check out http://wheelweights.net/ You could always go super-expensive and get custom wheels made by Fikse and get the exact size you wanted. |
the wheel weights site is a great resource, thanksfor posting it, and you are right about the aerodynamic standpoint.
the reason i recomended 16's is because it will be easier to find something in the same size range, although like you pointed out, lower profile usually come in wider widths. |
tires and rims
Some of the members have thrown out some really good points.Off the aero forum there's discussion about rolling resistance and inflation pressures,and I've been accumulating stuff to share but not ready yet.When I saw your post,I'd been reading a few nights ago and here's a few notes from the proprietary GM concept tires for the Ultralite 100-mpg car.An overall larger diameter ( 18-inch )tire has reduced R-R due to the fact that each tread element "see's" the road surface fewer times for a given road speed.Surface speed is constant,but greater circumference reduces revolutions per mile ( kilometer ) and each tread block and it's accompanied sidewall elements bends and recovers fewer times per revolution.Inflation pressure is 65-psi to pump up the "air-spring" which a tire is,which helps hold the tread flat against the road ( traction,braking ,and less deformation).The sidewall is very short ( to minimize deflection under load ) and has a designed-in curvature to help it deform,when striking road irregularities and hazards so as to absorb vibration which would otherwise be transmitted into the cabin of the car.The tread is kept narrow to minimize aerodynamic loading on the car,and each tread block is "hinged" so as to deform as freely as possisible when it strikes the road surface ( this also makes for a" noisy" tire,now regulated in the US by EPA ).Rubber compounds are balanced to allow as much hysteresis ( the ability to absorb,then release energy without heating-up ) and still allow wet and dry traction.Michelin used silica in it's "Green-X" tires for reduced rolling resistance and they ended up shocking people with static electricity and had to be re-formulated.The whole business is fraught with trade-offs.By the way,while under-inflation can remarkably lower mpg and shorten tire life,over-inflating,beyond the car-maker's recommendation shows no appreciable gain in mpg and you run the risk of reduced contact-patch and trouble associated with all that.Magnesium is out-lawed in the U.S. by DOT as it breaks when struck.Forged-aluminum is best bet for mass reduction.Polar-moment-of-inertia is an issue,and you want mass away from the extremities of the wheel/tire unit.The steel wheel can take wheel-covers,which is good for aero.Cast aluminum wheels can be as heavy as steel.Take a scale with you.I do! Hope this doesn't muddy the waters for you.I spent $1,000 to put larger aluminum wheels on my CRX so I could run the Michelin tires,and they made no improvement in mpg.They did have excellent wet and dry traction,so the experiment wasn't a total loss,however no mpg for "one-large" really hurt! Good luck!
those stock 15 inch steelies weigh 18 lbs apeice btw (no tire)
Hx rims weight 12 lbs and will fit with a small spacer or a little grinding of the front caliper of your EX. You can usually get a set for under $200 in good condition with tires. |
great post aero head, lots of usefull info!
so in conclusion (correct me if im wrong):
1. a larger rim + tire combo CAN be lighter if attention is paid, helping FE 2. larger rim is generally less aerodynamic and takes a wider tire, hurting FE 3. larger rim size means that more of the LRR tires will fit (possible negating the effect of #2?), helping FE 4. larger rim and OD reduces rpm's, helping FE about a larger rim being less aerodynamic... would some of this be countered some if I installed dams in front of the wheels? Or would it have to be skirts... |
the reason the lighter wheel is usually less aerodynamic is because they have more holes in them which allows air in to cause drag, this would be combated by either wheel skirts or flat covers (yep kill the cool effect)
out of curiosity have you seen the list of lrr tires, you may want to check into those. so yes the first 3 points are accurate generalities with number 4 almost always being true (if i understand though there is a point of diminishing returns) |
Yea theres a good wikipedia article on LRR tires... I'm assuming that's the list you're talking about. Whichever rims I choose to upgrade to, I'll be sure they can accommodate one of the tires on that list.
yea, part of the reason for my upgrade is looks, admittedly, so I think the wheel skirts are out. front wheel dams I can deal with though. |
tires and rims
