Torque converter lockup control relay setup...
This is the relay setup I came up with after looking at the starter kill relay setup over at this page at the12volt.com. :D
http://i677.photobucket.com/albums/v...r-11112819.jpg My thread over at ToyotaNation.com... ;) |
Here's how the DPDT (double pole, double throw) switch will be configured...
http://i677.photobucket.com/albums/v...r-11143450.jpg The yellow wire from the relays will return back to the solenoid leg of the switch. :D |
Did you ever get this to work for you?
I was thinking about hooking up the brake disconnect switch to the first solenoid ground wire. This will de-energize the solenoid when the ground is disconnected. I've been looking to build a plug and play adapter to connect in between the wiring harness and the transmission socket. This would allow me to test it without cutting into the wiring harness. :D |
Can you explain what you mean by using a resister per car? This looks interesting to me as I have an automatic.
