Torque Sensors for car. To control Electric assist.
E-bikes often come with a torque sensor in the crankset that feeds a signal to the motor controller where the user can then choose the amount of pedal assist they desire.
These systems can be/are overridden by a std electric bicycle brake style throttle that could easily be integrated with the std foot throttle control in a car. IMHO this is the easiest method of getting a DIY electric assist system to work with a ICE powered vehicle. The sticking point for me has been the lack of 'bolt on' torque sensor. These guys seem to have all the bases covered:
https://www.methodesensor.com/indust...orque-sensing/ Some Others: https://binsfeld.com/torquetrak/markets/automotive/ https://binsfeld.com//shaft-strain-gaging-guide https://melectric-systems.de/en/prod...%20Gelenkwelle Amongst other things, THE DRIVE SHAFT SYSTEM IS USED FOR:
Then again, the supplier hasn't considered motor control. https://melectric-systems.de/wp-cont...e-1024x504.png |
Some success with a sine/cosine sensor on the output shaft, but thats 20 year ago tech. The stuff I see today reads the lag angle directly from the power magnets via current sensing. Does require motor qualification during setup and tricky programming.
You want to measure that mechanical torque and tell an electric motor, supplementing the engine, to supply some % of the number read by the sensor. ie: You don't want to sense the torque supplied by the motor but that supplied by the engine that is under your direct (foot) control. The E-bike sensors look like this: https://www.schaeffler.my/remotemedi...en_preview.jpg |
