Toyota to give royalty-free access to hybrid-vehicle patents
https://www.reuters.com/article/us-t...-idUSKCN1RE2KC
Not sure if this was posted or not. Anyway I wouldn't complain if some scooters sized vehicles started getting synergy drives as an alternative. Though I expect the rubber band approach to be the most cost effective for a long time, which is probably 95% of the reason you are on a scooter in the first place... Sigh. |
Using an electric motor to get rid of the rubber band and excessive gear ratio those things use would boost their efficiency quite a bit...
But how do you get access to them?
