Toyota Yaris Hybrid R (420 hp, AWD)
1 Attachment(s)
Yeah, I kinda laughed when I saw the specs too. Interesting vehicle and technology though. 1.6L direct injection turbo puts out 300 hp. Then it has two 60hp motors for a combined 420hp. Oh yeah, and its AWD (FWD = gas, RWD = electric). Sounds fun.
Toyota Yaris Hybrid R Video, First Look | AutoGuide.com News Toyota Yaris Hybrid-R Concept Armed with 420 Ponies | AutoGuide.com News Toyota Hybrid R 420-HP Powertrain Detailed | AutoGuide.com News http://ecomodder.com/forum/attachmen...1&d=1379012178 |
Another cool thing it mentions is the 'traction control' system doesn't kill power to the engine if it detects wheel spin. Instead it engages the generator to charge up the pack if the engine is putting out too much power. Neat idea for a race car.
Ill bet
It is bullish in and out of corners I had a jeep commander that was all time command track. It was like driving a sherman tank under accel .
It uses super-capacitors to provide 40HP for 10 seconds or 120HP for 5 seconds (in the race version). I need to start reading up on the capacitors now... that sounds great.
What kind of mileage does it get?! :D
Toyota Yaris Hybrid-R Concept Revealed In Full, Debuts Frankfurt edit: Oh wait, they were comparing it to the current one,... I haven't seen any mpg numbers then, but only been searching a little. |
I bet you could do pretty good with a 1.6L direct inject turbocharged engine... IF you could keep your foot out of it!
Looks like something that is built to hunt down and kill Fiat 500s. It's the black sheep of the mini-car family, completely rogue.
I like it :) |
My question would be Is there an EV only mode? Then you could have the best of both performance when want it and efficiency.
If I were in the market and that was on the market, I would totally be looking at one of those.
The articles keep saying it's a GRE, but I don't know what that means? It's not the engine code, because E stands for electronic injection whicch this is not. I agree with night9, there's a boost button, there better be an eco button (at least on a production, non-racing model). I wonder if they employed Valvematic tech or left it old school with a throttle. |
As the owner of a 2007 Yaris this is my dream Yaris hybrid:
add the following to the stock Yaris 1. 1 meter long boat tail 2. full under tray 3. improved front end aero... 4. Cd of under 0.20 5. 2 rear wheel 10kw motor/generaters 6. 100kg plug in battery pack 7. all the controlers & stuff... For a resulting FE of 2.5 L/100km [94 mpg]...& preformance to boot |
I'm a fan of the 1nzfe
In thinking about the rear wheel hub motors, it occured to me that the more powerfull the hub motor/generate the heavier it is. the other question is how and when would AWD be of use? Low traction conditions such as snow, ice and wet mud . This would only need low HP, on the order of 3 - 6 KW [4 - 8 HP] per rear wheel. The other advantage of this type of layout is it is independent of the gas/diesel engine and can be programed for all sorts of things...
