Toyota's approach to improving ICE efficiency
Very nice! :thumbup:
Toyota's strategy is quite interesting, even though at a first sight that engine could be initially pointed out as "outdated" due to the absence of a turbo. But it's still surprising how far the ICE can be improved before resorting to the expenses of forced induction (even though I actually like the altitude compensation provided by a turbo).
https://www.youtube.com/watch?v=hSEUBWVfarQ You're correct. All modern turbo engines use computer controlled wastegates rather than vacuum controlled wastegates to manage boost. It gives small engines more torque at low speeds because they close the wastegate and go to boost when taking off. Rather than waiting for vacuum to finish before closing the wastegate. That's most of the secret to the modern turbo engine. Toyota are also following along with their C-HR having a 1.2T. |
40% is a fantastic peak efficiency. What will the average efficiency end up being?
What is the average efficiency of a typical engine? |
Direct injection is still expensive but is a huge step forward when paired with turbos since there is no fuel in the combustion chamber to pre ignite. And it is even possible to utilize multiple injections per firing cycle to get the exact stratified mixture and pressure profile all throughout the piston excursion. But it is expensive, complex, and noisy. Mercedes is achieving 181 hp/ Liter with maximum pulse boost pressures of 1.8 bar/ 26 psi. With flat torque of 450nm/ 332 ftlb from 2250-5000. In a family car.
. Mercedes A 45 AMG: The most powerful 4-cylinder turbo engine in the world . |
I'm pretty sure most of these gains come from cooled EGR. The electric water pump would only help a little, and the rest of the engine is unremarkable compared to the 2AR predecessor. Direct injection and high compression only adds a small bit.
It really just goes to show that older engines were just really held back for cost reasons. What is really interesting is that Toyota is sticking with relatively large displacement NA when Honda is committing to small turbo engines. |
My 16 year old motorcycle puts out 200 hp/liter with no turbo. I'm getting 47 MPG with all that power to weight. I don't get the appeal of powerful sedans. It's pointless in that a sedan is a practical vehicle, made uselessly fast and expensive. I'm getting older, and perhaps riding motorcycles has ruined my expectations for affordable fun. |
8:1 is an error. 9.8:1 is reported. And, that is only at idle. variable vane turbos crank up pressure quickly at low rpm's.
. https://www.edmunds.com/mercedes-ben...st-specs1.html . |
To my knowledge, Honda hit approximately 40% thermal efficiency (give or take) with the G1 Insight's engine back in 1999, without the Atkinson cycle, and slightly surpassed it with the 2L i4 in the 2nd gen Accord Hybrid. Honda cited many of the same technologies back in 1999. Makes me wonder why it has taken so long to make it into more mainstream engines.
I've done turbos and I've done NA. At the moment my heart -- and money -- is in the NA camp. The Toyota technology sounds promising. I drive two of their v6 engines currently; one is the seriously understressed 4.0 in my Tacoma pickup, the other is a more highly refined 3.5L that makes impressive power and torque when required, and surprisingly decent gas mileage the rest of the time. I'm eager to see this new tech in a Toyota v6.
I saw this article the other day about Mazda's new engine... Mazda
Turn up the compression, keep the cylinders big, employ Atkinson cycle because that works, laugh all the way past the gas station on your way to the bank. |
Bob Lutz once said...
Torque output of the HSC engine available in the old Tempo/Topaz twins was modest but decent at about 125-130 ft-lbs. |
Decades ago SAAB or Volvo figured that 36 lbs per horsepower was ideal. I rarely get my engine (Dodge 3.3L) above 3600 rpm and cruise at 2500 rpm.
Probably best to look at torque after the transmission. Two 200HP motors, one with twice the torque at the crank and the other with twice the RPM, both have the same output after gearing.
Except that the modern engines use new techniques for efficieny such as Atkinson and high egr. Or ulta high effective compression ratio with turbos and direct injection along with minimized surface area to lose less heat energy via smaller displacement.
Larger displacement makes for more surface area in the combustion chamber to pick up heat which is wasted energy.
Agreed. Undersquare is a key to heat efficiency in piston engines.
Cars were plenty "fast" in the 1960s before weight and emissions ruined a good pairing. Good relative highway fuel mileage as well. Load the sedan to maximum capacity. Or hook up a trailer that represents the same. In each case 0-60 in 20-seconds has always been considered good. 30" is just at acceptable. Steady state economy should factor. Along with running air-conditioning, power accessories and the rest. What only a really big cubic inch engine in a luxury car could do. More than this is kinda stupid. Everyone likes to cruise effortlessly. And great mpg with a great ride. |
