EcoModder.com
-   -   Tps lod not always constant (https://ecomodder.com/forum/showthread.php/tps-lod-not-always-constant-29449.html)
Hondamate 07-10-2014 01:01 AM
1998 honda civic hx
For a while I was able to get A lod of 57 while at 17 tps in 5 gear. However, now it seems that I'm only able to get the lod at 60 or 61. Nothing has changed. I haven't done anything to the car. Thanks
Baltothewolf 07-10-2014 01:52 AM
What's lod?
RobertISaar 07-10-2014 10:50 AM
based off of raw numbers with no scale, sounds like manifold pressure in kPa?
Daox 07-10-2014 11:04 AM
There is a reason why TPS and LOD are different numbers. A given TPS will not always give you the same engine load. There are way too many variables including rpm, air temperature, humidity and more.
Hondamate 07-10-2014 10:13 PM
Come to think of that, I remember looking at the air filter to see if it was clean. Do you recommend k&n air filter for reduced lod?
When it gives me lighter lods I'll have to see what else is going in then
RobertISaar 07-11-2014 12:14 AM
a k&n is great if you hate efficient filtering.
Hondamate 07-11-2014 01:28 AM
I'm not sure what that means
RobertISaar 07-11-2014 01:33 AM
k&n air filters don't filter air very well.
digital rules 07-11-2014 06:56 AM
Keep the stock filter for best MPG. K&N filters may benefit high performance enthusiasts, but not any real benefit if max MPG is the goal.
Surprisingly a dirty filter has no affect on fuel economy with EFI engines, as the computer will adjust A/F mixture accordingly. It does make a difference on carbureted engines though.
http://www.fueleconomy.gov/feg/pdfs/...02_26_2009.pdf
digital rules 07-11-2014 07:19 AM
Yep, the K&N won't catch finer particles as well as a stock filter. Avoid K&N if you want the engine to last a L-O-N-G time.
Hondamate 07-11-2014 01:02 PM
Oh, thank you for clearing that up.
