Old 09-15-2009, 03:27 PM   #1 (permalink)
Wonderboy's Avatar
The Fruit Bat - '01 Honda Insight
Last 3: 54.26 mpg (US)
Current - '21 Subaru Impreza Wagon
90 day: 34.36 mpg (US)
Calculating amp-hours
After Ben's purchase of a ford escape hybrid battery pack on the cheap from ebay, I've recently been considering buying a hybrid battery pack to use for my pure EV conversion. Most hybrid battery packs are way over the voltage I'll need for my application... however the amp-hour rating is far lower. How does putting half the cells in a hybrid pack (or any pack, for that matter) in series affect the amp-hour rating? If I were to take a 144v pack for example and make it into a 72v pack, would its amp-hour rating increase and how much? I'm just brainstorming on how I could make a NiMH pack for cheaper and with comparable amp-hours to a bunch of lead-acid deep cycle batteries at the same voltage.
Old 09-15-2009, 04:42 PM   #2 (permalink)
baddriver's Avatar
94 Corolla - '94 Toyota Corolla DX
90 day: 29.38 mpg (US)
Connecting Batteries in Series or Parallel
The Following User Says Thank You to baddriver For This Useful Post:
Wonderboy (09-16-2009)
Calculating Rolling Resistance SVOboy EcoModding Central 2 02-15-2012 08:43 PM
Replacing alternator with solar panel array on roof? blackjackel EcoModding Central 91 01-19-2012 09:19 PM
Battery amp meter watt-a-mezz Fossil Fuel Free 5 09-13-2009 12:31 AM
Progressive Automotive X Prize Calculating MPGe pgfpro EcoModding Central 5 09-01-2009 02:17 AM
My eventful 24 hours (GM conference and car troublez) SVOboy The Lounge 6 05-08-2008 11:33 PM
