Traffic Jam is Killing my MPG
The KM reading from my home to work is just 15km translating to 9.32 Miles and imagine that it takes me an hour and 15 minutes to get there. So you can imagine the traffic that I am facing everyday. Ultimately wasting gas. I drive a Honda civic 05 4 door sedan. I guess its not my driving style since I am so conscious nowadays.
The only modifications that I have are these: 17 inch magwheels (might add to the weight- not sure with my tire specs) Subs at the back of my trunk(might add to the weight) Royal Purple (10w40 should I go thinner?) Any inputs guys? Is there hope? |
Some hope but if its as jammed as it sounds, no mods will really matter other than finding a different route that isn't so congested. Other option include:
DRIVING > creating a larger front buffer gap in front of you > neutral coast when possible (easier if you have that gap) > neutral idle if you must idle > engine off if nobody is moving > turn off all unnecessary accessories (A/C, radio, coffee maker, etc) > look into alternative route TIRES > make sure the tires are pressured up > opt for low rolling resistance tires > look into lighter wheels WEIGHT > put your car on a diet > put yourself on a diet ENGINE > go as thin as you can but make sure your car can handle it. Some recommend synthetic or 0w but I have no experience with that. |
Thanks bro for the reply. I have further questions:
For driving here are my questions: they say that in neutral driving, the air-fuel mixture is 1:1 as compared to geared, the ratio is lower in favor of the air. since the ECU thinks that you are going to do an engine break. how true is this? For tires can you suggest a specific magwheel combined with a specific tire with low resistance rolling? |
go hybrid mod !
or for the lazy mod try the big battery mod. power for ignition is 17% of fuel costs at low speeds. if lights are on in traffic jam its even more. http://ecomodder.com/forum/showthrea...or-4675-2.html |
15K? Ride a bike! 1/2 of a pint of lube / year-- How's that for fuel efficient?
I would try a bike, you'll save a lot of gas and about 45 minutes, :)
gasti_ako -
Many newer cars will run lean "by design" when the car is decelerating in gear. Some cars will cut off the fuel completely until the car's normal "idle RPM" is reached. All cars will run rich when the driver is driving for performance. The 14.7:1 ratio is used because the emission standards in the USA require this ratio. Otherwise, the catalytic converter won't function properly. What are the emissions rules in the Philippines? Do you have a catalytic converter on your car? I agree that a bicycle/scooter/motorcycle would be better, but I also think you get a lot of rain, so it isn't practical for work. Can you commute with a coworker? CarloSW2 |
gasti_ako -
Here is a great thread on how the air/fuel ratio works with emissions : http://ecomodder.com/forum/showthrea...nomy-4376.html Here's the article the thread is pointing to : Autospeed - Running Lean for Economy Quote:
I am also agreeing with you with alternative modes of transportation, in fact I take the train most of the time. My car has been a weekend car so to speak. I just want to make sure as well that its the traffic and not the car or driver which/who are the source of low MPG. When I went highway driving, I got 33 MPG. Though I am quite speeding at around 60 M/hr. So I am thinking that my highway driving MPG could have been better. In addition, i think my wheels being a 17" is also a factor. That is why I am changing it when its time to change my tires. |
