Traffic lights.
Since starting on the Hypermiling drug I have discovered something about lots of traffic lights here in Scotland. Lights on the main drag are geared to through traffic, and don't change very often for crossing/joining traffic. They have sensors set into the road, within 10 metres of the stop line, and until you make that sensor the light stays on red. Without making the sensor the lights will change, but it can be once every 5-7 minutes, depending on the time of day. It kind of spoils trying to time the lights.
http://i.imgur.com/Rfvnxtt.jpg |
It's not always easy, but the trick is to get someone else in front of you to change the light! :D
I have read about bikers fitting magnets to their bikes so that the sensors see them as a car and change sooner. unfortunately fitting a magnet to a car doesn't do much.
Most traffic lights here is sweden work well with this system. At night on a quite road you can just keep driving at normal speeds even if it is red and 9 times out of 10 it will go green just before you need to slam your brakes on (so as not to run through a red light). |
I tried it out on the roads and got mixed results, so it might depend on how they are positioned or it only works on a few particular cameras. |
I found that too. As you approach you stick your full beam on and they see you sooner.
