EcoModder.com
-   Alternative Transportation (https://ecomodder.com/forum/alternative-transportation.html)
-   -   Treadmill Motor (candidate for e-bike?) (https://ecomodder.com/forum/showthread.php/treadmill-motor-candidate-e-bike-1593.html)
sharp21 03-29-2008 07:15 AM
The treadmill here at work is opened up for maintenance so I took a look at the motor. Here are the specs:
3HP Continuous Duty @ 13vDC / 2672watts
It is 11" long x 4.5" dia, with a 1.5" shaft.
There is a also a fan connected to the end opposite the drive shaft.
So would this be a decent bicycle motor?
S.
MetroMPG 03-29-2008 08:09 AM
Except for the fact that it's way big, and probably pretty heavy (25 lbs?), the specs are fine. In fact it's likely overkill for an e-bike. Run that at 24 volts and you'd have a silly fast machine.
AndrewJ 03-29-2008 02:57 PM
Yep, what Darin said.
Overkill, especially considering that the biggest electric scooter motors (good for +35mph) are just over 1000 watts.
Oh, and Ben Nelson's motorcycle uses a 4hp (continuous) Etek motor.
sharp21 03-29-2008 04:26 PM
It IS a little long, but it could be centered with a jackshaft arrangement.
Maybe for a motorcycle then? Obviously treadmills get going hellu fast, but I would have thought that their motors would be made for high rpms as opposed to the torque needed to get a bike moving.
S.
MetroMPG 03-29-2008 04:58 PM
It'd probably work well for a low speed motorcycle or moped type of EV.
hondaworkshop 03-29-2008 05:05 PM
Sounds like a perfect candidate for very a fast ev-kart to me.:D
Ryland 03-29-2008 05:50 PM
What brand of tread mill is this on? just in case any of us wanted to get one for our selves.
If you ever used that motor at full power it would draw 205 amps, that is alot of amps! you would need 2/0 or 3/0 wiring, that is .40" to .46" diameter, so with smaller wire size you are never going to get full power out of that motor, so basically you are going to have a motor that will never be over loaded, and should never wear out, with that you should be able to up the voltage and be fine with 24V battery and speed controller.
HotRod 03-29-2008 08:33 PM
Can you post a pic of that?
sharp21 03-30-2008 05:31 AM
I think its been put back together, but Ill try to get a pic of it.
Either way, the next one that breaks down, the motor is mine!
S.
ElectricZX2 04-02-2010 03:45 PM
Any progress on this? I was thinking about doing something similar...Are you sure it isn't 130 volts? i have a treadmill motor that says 2.5 horsepower, 130 vdc, 18 amps. Its a PM motor so you would need a speed control right? some smaller motors r 90 volts. High voltages are used to keep the current down.
NiHaoMike 04-02-2010 06:16 PM
AFAIK, the most powerful hybrid racing bicycle is 16kW.
Endless-sphere.com • View topic - P R O J E C T "Y" KILLABICYCLE World record 17 june 2009
2.6kW would be good if you're looking for fast acceleration, but it would be bad for range.
vectorges 05-30-2010 09:17 PM
Treadmills show up on Freecycle occasionally. Usually the belt is broken. The electronics and motor are pretty foolproof.
