EcoModder.com
-   OpenGauge / MPGuino FE computer (https://ecomodder.com/forum/opengauge-mpguino-fe-computer.html)
-   -   trouble finding 5.1v zener diode (https://ecomodder.com/forum/showthread.php/trouble-finding-5-1v-zener-diode-7013.html)
junker 02-06-2009 04:34 PM
Assembled my freeduino, interfaced LCD, prgrammed with MPGuino software, tested, now need to interface to my vehicle.
I like to order from digikey and am having trouble finding the 5.1v zener diodes that are necessary.
The only one I found is surface mount, which I guess I could solder wires onto but was wondering if anyone could point me to a more appropriate diode. If you have a digikey part number even better.
Here is the one I found...
Digi-Key - MMSZ4689T1GOSCT-ND (ON Semiconductor - MMSZ4689T1G)
Much Appreciated.
dcb 02-06-2009 05:26 PM
This was the zener I started with and still use:
1N4733A 1W Zener Diode - RadioShack.com
You can probably search digikey for 1N4733A
junker 02-06-2009 06:57 PM
PERFECT, got it. -- thanks.
