Trouble getting a VSS signal
I have a 1988 Honda Prelude that currently gets about 33 MPG highway. I just recently attempted installing an MPGuino. I don't have much experience with electrical work so this is a fun project.
I have everything connected and working with the MPGuino except the VSS signal. A couple guides online indicate that the ECU B10 yellow/blue wire is a VSS signal. The MPGuino does not read a signal from this wire. Something else online suggested using the ECU B16 wire, but the schematics says that is the crankshaft sensor ground. I tried it anyways. I got a signal but it definitely was not the VSS signal. Since I can't get a VSS signal from the ECU wires I thought I should go direct to the source. I can't find the VSS sensor on the engine though. Here are some pictures of my engine. https://i.imgur.com/j11Wjyc.jpg https://i.imgur.com/ZAbobpp.jpg My question for the Ecomodder experts, where should I get a VSS signal? |
VSS sensor is generally on the gearbox. Google shows it as being on top of the transmission and having a black plastic connector on top of it.
Simon |
Are you certain there really was a electronic speedo then? The civics were still cable driven until 1992. Maybe the Prelude had more features. Maybe it had another way of reading speed for the ECU but I doubt that.
Have a look at this thread as it shows thew VSS sensor and also the gearbox clearly. In your second photo it should be buried somewhere under the distributor and on the top of the gearbox Simon |
1FunRyd's 88-91 Prelude - Auto to 5 speed swap, B20A - H23 Non-VTEC swap - Honda-Tech Simon |
That looks nothing like the VSS I was looking for. My googling gave me a different looking VSS.
Hope that helps
Simon |
Some 3rd gen Preludes have cable, some have electronic. You can buy replacement cables for third gen Preludes from RockAuto and other major carriers. I'll bet diff trim levels had diff specs... you need to follow the check this guy recommends in this Prelude forum thread:
"To check, just look down at the top/rear edge of your transmission bell housing, near the shift linkage. If you see a box with wires, it's electronic, otherwise you'll see a huge cable. Have a look, it's not hard to differentiate them." Broken speedo cable...easy to replace? - Honda Prelude Forum - PreludeDriver.com |
I I decided to go another route. I read another option was to connect it to the speed sensor wire behind the dashboard. I am now getting a speed signal. The problem now is that the speed is greatly exaggerated. 5 mph = 25 mph and 60 mph =160 mph.
Maybe it just needs calibrated. I am not sure. to connect it behind the dashboard. I am getting a signal |
assuming you haven't picked up the tach signal, then yes...it should just need calibrating.
Not sure on the older models, but it looks like a lot of Hondas use ~8204 pulses per mile. If yours is different, I'd change it to that for starters. |
All solved. I needed 33450 vss pulses / mile. I confirmed that the speed was accurate with my phones GPS. I think the reason it needs to be so high is because the wire I tapped into is the vss signal after the vss signal amplifier. The mpg values look mostly accurate at the moment.
Thank you everyone |
