Truck Bed Cover Ideas
I have had an idea for a bed cover for a while, but now that I know how to use Google SketchUp well enough to make poor drawings, I don't feel as bad posting my ideas.
http://i378.photobucket.com/albums/o...edanKamm-2.jpg Basicly a typical truck looks like this. http://i378.photobucket.com/albums/o...edanKamm-3.jpg Most of the bed covers that people look into making look like this, or aren't even tapered at the end. http://i378.photobucket.com/albums/o...edanKamm-4.jpg What I am thinking looks more like this. With the tail gate down there would be a lot less trailing edge. http://i378.photobucket.com/albums/o...edanKamm-5.jpg Or with the "fins" tapered down. Obviously the fin tapers would have to be clear for the tail lights. Is there a reason for not doing this? The reasons I can think of are:
What kind of angle would that make? I think the only problem is that the angle might be too steep, but it's a great idea!
It looks like it would be tough to actually use the bed of the truck. With the 'traditional' design, you can open the tailgate to get access, with your design, you would need to make a hatch type of door onto the back, and it looks like it might be tricky to reach stuff at the end of the bed with that setup.
It looks pretty cool though, like a concept car with crazy fins at the end. |
Wow. Lovely car, that one, Frank.
--- I suspect even with a long bed, the angle would be too great to keep attached flow, even if the transition at the cab roof end were more gradual. Where's Ben Nelson. He had a REALLY good & novel aeroshell idea, but I think I promised not to tell anyone. Come on, Ben - spill the beans! |
PIMP car! I wasn't even sure what I was looking at right away due to the mirror finish, but I would definitely feel cool driving it.
Basically I imagined a "final" version to be hinged at the top like said above... basically the entire flat area would be liftable, with some sort of lift assist. It may not be practical for many reasons (the tailgait may bounce freely and cause problems. It may require windows too... Just an idea that could be expanded on by anyone. As for the question of whether it would maintain flow or not, that's another question (and my third bullet for why it may not work), and would be heavily dependent on the truck you are using. The short bed trucks would probably never work, but I would imagine most full size beds would be under that magical 15 degree angle. Even if you had to have the back end raised up a few inches to keep the 15 degrees, it just gives you a bit more length to boat tail the truck. |
Tonneau Cover Based Idea...
A tonneau cover based idea...
http://i378.photobucket.com/albums/o...edanKamm-6.jpg Take your basic tonneau cover, as shown above... http://i378.photobucket.com/albums/o...edanKamm-7.jpg Build an extension on the truck bed sides that slopes to the end of the bed. Also, you will need to build a "bridge" to fill in the gap to the back of the cab. http://i378.photobucket.com/albums/o...edanKamm-8.jpg The tonneau cover can still open as before, giving access to the bed of the truck. http://i378.photobucket.com/albums/o...edanKamm-9.jpg From the side, you can see that there is an arc built into the bridge, allowing a smooth transition. My 3D model isn't the best, and neglects lots of things like space for the cover to open without contacting, but you get the general idea. Also I will point out that the cab in the first picture has (heavily) tapered sides, and the following ones do not. It should be easy to put windows on the sides and the portion behind the cab to allow viewing out the sides. Although I had this as an "epiphany", I know there is a very professionally done one out there somewhere that looks just like this, and I didn't even think of it until I had it drawn up and said "this looks very familiar". Does this seem feasible to folks? |
Feasible, and... already built by Bondo, as you remembered:
http://ecomodder.com/forum/showthrea...d-cap-583.html Have a look through his thread: swiss army knife of aeroshells. |
bed cover
Wyatt,it's hard to tell true-length and actual angles from an orthogonal projection as in your renderings.So it's hard to figure if you'd have flow separation down the back slope of the cover.Metro MPG put a template together for his permanent Kamm back project,that represents a generic teardrop shape that we think is a good starting point for design.---------------------------------------------------------- If you can rotate your image until it represents a side view of the pickup,it would allow you to place it under the template and see if your angles are within the margins.----------------------------------------------------------- If the cover descends at a steep angle,the flow will separate and you'll lose the benefit of the cover.If you can find your way to the Phil Knox aerodynamic photos in the archive,there you'll find a photo of the famous Kamm K-Car,taken in Volkswagen's windtunnel.From the smoke trace over the roof of the car,you'll be able to see the "perfect" contour up to about the last foot or so,where you can see the air separate as the roofline rolls more steeply down.If you mimic this contour,you're home free!
That's the one I saw! He has quite the following, and his craftsmanship puts my model to shame! I've heard this one said, "There's nothing new under the sun", and it applies here too I guess.
Using Bondo's design, could the shape be extended (at the same angle) a couple of feet beyond the tailgate with additional FE benefit?
At least in California the law used to allow something to extend up to 3 feet beyond the rear of the vehicle without having to hang a red flag on it--not sure if that's still the law or not. Of course that would complicate the rear lighting issue. Ray Mac |
( It's nice to see a truck forum not bad mouthing EM and taking it serious :thumbup: ) So I too have thought of that fourth design, ( haven't we all ) and I was wondering if the question was ever answered, regarding what makes the 'finned' version an inferior design. ( never-mind the angle of the aero shell - I'm just talking about the sides of the truck that become the 'fins' of this design. ) I'm guessing there would be no benefit because you would still get the spill over that results in a vortex. The air in that area is moving upward to where the tail-lights are and spilling over, not going straight back like we think it would. |
Batman Junior & wyatt -- That would be ZZTop's Cadzilla; possibly the finest custom car ever.
I think the designs are reasonable, just add a circular arc instead of the angle and flat top. Edit: Just noticing now that it's a zombie thread. Cadzilla is still the best. |
Wow that looks slick, nice pics. Too bad they are probably mega vortex generators. But sometimes style is worth it!
