Old 02-24-2009, 08:03 AM   #1 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
2009+ Honda Fit - ideal rear design for Kammback
I saw a 2009 Honda Fit in the metal for the first time a little while ago (yes, I live a sheltered life) and the very first thing I noticed was how the rear lines have really pronounced plan & profile taper:
The converging arcs suggest the beginning of a proper teardrop/airfoil shape.
Which of course led me to think: it would be an ideal starting point for a very organic Kammback extension to improve aero.
Old 02-24-2009, 08:18 AM   #2 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
That seems to be the trend in new cars, an "incorporated" Kammback. Check out the 3-door Citroen C4.
Here's another example, from a different weight class. The Renault Trafic and Opel Vivaro van has rear light columns which aren't flush with the sides or the back, but allow the sides to curve inward, sort of like the sides of a short Kammback.
Old 02-24-2009, 09:03 AM   #3 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Look at the Fit Sport - it has a lip spoiler at the top, built just right for aero.
Old 02-24-2009, 09:09 AM   #4 (permalink)
I gotta say I love the Fit, and a boat tail on it would be soooooooooo sweet. Just give it a lower 5th gear and you would really be cranking out some awesome mileage!
Old 02-24-2009, 01:00 PM   #5 (permalink)
Hi,
I think you can get it with 15" steel wheels -- so you can put smooth wheel covers on it! A grill block for the upper grill would also be an easy thing to do...
Old 02-24-2009, 02:35 PM   #6 (permalink)
I had to go looking for a good pic of the car without that spoiler, because I don't think it's an ideal design for MPG - appears to me to angle upward slightly from the angle at the end of the roof, rather than continuing the downward sweep of the roofline.
Old 02-24-2009, 03:20 PM   #7 (permalink)
Hypermiler
Wagons
A coworker has one, and it follows the same line as the last bit of the roof. I think the bumps for the hinges play some optical tricks.
You're right, though, that it could curve down a bit more for the best aerodynamics.
Old 02-25-2009, 12:34 AM   #8 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
I dream of opening the door my garage and finding a Citroén C4 Diesel in my space. Once Honda rivals the utility, efficiency, and emissions of European counterparts, I'll be the first to sign up.
If the Fit is indeed as efficient as most Euro-spec 3- or 5-door hatchbacks, I applaud them. If not, I patiently await...
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 02-25-2009, 12:48 AM   #9 (permalink)
FastPlastic's Avatar
98 Cherokee - '98 Jeep Cherokee
90 day: 17.18 mpg (US)
ZX7R Ninja - '99 Kawasaki ZX7R Ninja
90 day: 42.45 mpg (US)
Just having some fun with Gimp (free photoshop knock-off). It would need some glass to work.
Name:	Crazy honda fit idea.jpg
Adjusted for my driving habits. 80%city/20%Highway.
20mpg city/30mpg highway or bust! Check out my mods so far
Old 02-25-2009, 01:15 AM   #10 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
FastPlastis -
That is sooooooooo cool! That (probably accidental?) rear window detail from the stretch is totally mannerist. If I were doing a teaser-ad, I would only show that window :
CarloSW2
American Solar Energy Society
Honda Fit Belly Pan Project Fit Aerodynamics 17 08-10-2015 08:29 AM
2008 Honda Fit -- Opinions Siaharok General Efficiency Discussion 32 03-09-2011 10:29 AM
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 10:45 AM
Ecomodded Kia Ceed. Factory fit ecomodding!!! Unheard EcoModding Central 15 09-18-2008 08:31 PM
Honda Not Bringing Fit Hybrid to the US SVOboy EcoModder Blog Discussion 13 08-25-2008 08:37 PM
