truck tires
Any recommendations on truck tires for better mileage. 1998 GMC k1500 1/2 ton extended cab, current tiress are p245/75 r16. Would maybe like to go a little narrower to reduce footprint but want to keep load capicuty as once in a while I do haul a ton of wood pellets.
Only put on about 6000 miles a year Thanks Gary |
With work truck tires bigger is better.
If you go narrower you will start to lose load capacity fast. General tire has a LLR tire in that size. |
I like my 235/85 tires, but 215/85 would be the same diameter you have now. I'm not sure how the load capacities compare.
As a general rule, the bigger the tire size, the lower the rolling resistance - bigger meaning any of the 3 dimensions used to describe a tire size.
HOWEVER, the effect is small compared to the differences between tires - meaning make and model. Unfortunately, there has not been much published on the RR of light truck tires. But you need to be aware that RR, traction (especially wet traction), and treadwear are part of a technology triangle. To get improvements in one area, one (or both) of the other areas has to be sacrificed. |
An E-Rated 215 85R16 is going to have very similar load capacity to the others. I'd go with that since it's the narrowest.
An Load range E tire will carry several hundred more pounds per tire than a standard LT truck tire.
A 245mm wide LT truck tire will carry between 2200 and 2300LB and a 215mm wide load range E tire will carry at least 2600lb. |
Is your truck 4x4 and do you need any off-road ability?
My truck came with very narrow (235/85-16) road tires that had a high load rating and got excellent fuel economy. The problem was that I got stuck on damp grass even in 4x4 on a very gentle slope. Since I frequently go off-road, I needed something wider and wanted something taller to reduce my highway RPM. I put 285/75/16 Bridgestone AT Revos on to give me a balance of good on and off road performance, fuel economy, wear, and road noise. The load rating was lower, but that didn't stop my dad from hauling 20k lbs of excavator and trailer on a ball hitch :eek: |
6 of one, half a dozen of another. I prefer skinny tires off road. |
I just put new tires on my truck. They are 235/85-16
They are bigger than original 215/85-16 and seem to grip very well. I needed something that could dig through snow and mud and sand and get me to the firewood. After looking over the local selections, I felt the Cooper S/T Maxx was the best bet. They are MEATY. I am unsure of the mileage so far because I sprung a gas leak about the same time I put them on. So far it seems to be the same even though I have been trying to find places I can't go....:D They have taken me everywhere I have wanted to go this week. I will get pics of the hills I have been climbing. Not trying to sell tires here, just amazed with mine..... I am keeping mileage logs and will post up when I get a few tanks run through. |
When considering the flotation of tires, comparing skinny vs. wide, always remember what the letters "PSI" mean and that the "P" is fixed by the weight of your vehicle.
But you also have to remember that flotation and traction are two different animals.:thumbup:
On a half-ton truck I'd avoid high load index tires (Load Range E). Stick with original size range as well, but in an LT designation.
The trade-off between LRR truck tires -- let's designate closed shoulder "highway rib" tires as such in the interim -- and traction tires needs to be cleared up by the OP as to whether low-traction but high miles/high mpg tires are a good choice. With so few miles to accummulate over seven years (projected tire life) I don't think this is going to matter in any significant way. . |
I have done a bit of driving this week with my new tires and they make the truck work harder all the time.
I did the math and I should only be losing ~6% of my rear wheel power. It does not sound like much, but it is noticeable. Climbing hills is harder and I often have to downshift, but level ground is not too bad. Getting up to speed takes more effort and time. I had a hard time going 60 mph with a load of wood on Saturday. I had 235-80/16 on there before and it felt fine. The new ones should only be a hair bigger, but they stand 2+ inches taller. I think it is the deep tread that makes them a good inch taller alone. I think this whole problem will get better as the tires wear, but I will be getting smaller tires when these are gone. |
