EcoModder.com
-   -   Tune-up suggestions? (https://ecomodder.com/forum/showthread.php/tune-up-suggestions-10438.html)
RandomFact314 10-01-2009 09:56 PM
Hey, since I have got some money I have got new ceramic break pads for the front brakes, 2 new rotors for the fronts, just recently got new spark plugs and just now got new spark plug wires... I'm not exactly sure what I need to look at next, I know my air filter is decent... What other simple things should I look at? how much will that stuff cost to repair? Thanks for any help
Johnny Mullet 10-01-2009 11:32 PM
Fuel Filter (if equipped) and PCV valve would not hurt.
Christ 10-02-2009 01:14 AM
Not that it's worth that much, but the PCV valve is cleanable, and you can get away with just soaking it in some gasoline, so you don't have to pay the $3 for a new one.
Did you get the brakes w/ the lifetime warranty? If not, I'm sorry... :)
McTimson 10-02-2009 07:29 AM
If your engine has one, replace the distributor cap and rotor. Clean up your battery terminals, and check all your fluids.
Check the condition of your accessory belts also, and make sure they're still at the proper tension.
Chalupa102 10-02-2009 10:29 PM
Not sure if u have already done it, but if not, clean the MAF sensor. U may already know this, but if it's dirty, it can cause poor fuel economy due to an incorrect AFR.
99LeCouch 10-03-2009 09:42 AM
Throw in a bottle of Techron Concentrate with your next fillup. It'll clean out your injectors to atomize the fuel more completely.
Christ 10-03-2009 10:33 AM
When you do that, fill up with Shell V-Power, first... then you'll have V-Tech in y0 gas, d00d!!! :P
