Turbo With an Alternator
Thinking about putting a turbo in my car to overcome pumping losses and power an alternator so i can unbelt the regular alt.
The car has a carb. I'd maybe try to up to 6psi of boost on the engine for performance. I wonder if this could be done? Would the turbo spin at too high of rpms for the alternator? |
Given the design of a turbo this doesn't seen feasible. It might be possible to remove the intake side of the turbo and somehow rig the shaft up to a alternator but the drag created by the alternator would probably require the engine to be running at a high rpm in order to spool up the alternator there would be much more loss than gain. That doesn't mean that a turbo by its self is a bad idea for fuel economy if set up properly. I remember reading an article a couple years ago about a guy turboing his motorcycle for improved fuel economy I believe he called it improved volumetric efficiency
Turbos spin at 50,000 - 100,000 rpm. Alternators spin at 1600-12,000.
Formula One cars use a device called the MGU-H (uh... Google says Motor Generator Unit - Heat) to harvest energy from the turbo and to enable quicker spool up at transitional rpm. So yes, the possibility is there.
But these units are pretty high-tech stuff... there's a big electric motor splitting the intake and exhaust sides of the turbo, spinning at 100,000 rpm. I doubt you'll be able to make enough electricity off a regular turbo to replace your alternator... unless you're driving at full boost, all the time. Turbo boost is "free" power only in the sense that the boost the turbo provides counteracts the extra backpressure created by the turbo. If you disconnect the intake side, you're just making the engine work harder to spin those exhaust turbines. Probably won't be as efficient as an actual alternator. |
Wait a minute - you mean a turbo on the air intake, powering an alternator by the difference between atmospheric pressure before and the part vacuum behind the throttle valve, right?
That may work in theory, but you will have a hard time finding a fitting turbine. Also it would only work on part load; if you idle not enough air is flowing through the turbine to keep it spinning despite the large difference in pressure, and at WOT there is no pressure difference to spool up a turbo. I confess having thought along these lines myself. At 2000 RPM at 50% load my 1339 cc engine pumps 22 liters of 50% vacuumized air per second, that dissipates about 1.1 kW of power over the throttle plate. If you can get 25% of that in electricity, it may just be enough to sing it out for the day without an alternator, but you'd need to charge the battery at home. A bigger battery, preferably a lithium iron one, would be advisable in this setup. Anyway, subscribed...! |
Same theory as putting a windmill on top of your car. It's not free to push the blades through the air. Putting half of a turbo on the exhaust side and running it through a planetary gear reduction seems pretty plausible. Take a look at the centrifugal superchargers. They use a belt off of the accessory pulley to spool a compressor wheel... just use the same gearing and use an exhaust turbine to spool your alternator. A broken centrifugal supercharger on eBay could yield some fantastic parts... I really like the idea. :thumbup: |
Turbo with an Alternator is feasible
The turbo with an alternator is feasible and has been done. I don't know if they sell them now, but Garrett designed and built some turbos with a three phase motor/alternator between the turbine and compressor. Their objective was lag reduction, but with the appropriate controls, one of those would do what you want. That said, the design and development of such equipment is well beyond the capability of the vast majority of even professional engineers, it requires a team of engineering specialists. Like you might find at Garrett. As far as possible alternator speeds go, I have worked on the design, development, and test of alternators that operated WAY over 100,000 rpm. Windage, bearing, and magnetic hysteresis losses do add up, but I think you could go 1,000,000 rpm, if you could get the rest of the system to support that speed. That may have also have been done, on some space based cryo-coolers. There is a lot of stuff that never makes it to consumer media.
The comments about nothing being free are largely true, the only free energy I associate with a turbo, comes from the reduction of normal shock losses in the exhaust port due to the back pressure of the turbo. That shows up as about a 0.5% decrease in BSFC if you compare turbo, and non-turbo versions of the same engine from Yanmar, Kubota, etc. |
You still have pumping losses if its a gas engine.
Why not just get a turbodiesel (no isobaric losses), pull the belt off the alt and replace the alt output with solar panels and put the belt back on the alt for long night trips? |
Oh, intake?
To make 6 psi on an average-sized four-banger takes about 10-15 horsepower worth of power, going off of what Thomas Knight did with their electric superchargers back in the day. Normal operating vacuum wouldn't even be able to turn such a thing, let alone produce meaningful power from it. If you've ever dismantled an air intake and put your hand over the intake hose or carb ("burping" the carb to clean it used to be such fun!), you'll know how little vacuum it produces at idle or low rpm... much less than a shop vacuum. Now those vacuum motors have the equivalent of about 2-4 horsepower... So say you have about 1 hp of suck available at cruise... then consider some of that suck has to go to intake air to power the engine... you're getting much less than that going to the intake alternator. Consider it takes at least 2 hp to turn a regular alternator, and 10-20 hp at full electrical load, there isn't much of a comparison there. More effective to run a generator off the exhaust side. Cap the turbine speed by braking it down with a generator when at full load... also eliminates the need for a wastegate, as you can control maximum boost pressure, as well. |
At large alternator makes 160A, that's ~2.2hp at full load. Even with all the losses from crank to output, it won't ever take more than 3hp to drive it.
20hp is what it takes to drive a whole small car at freeway speeds. |
Would I be a pariah if I replaced my alternator with a tiny nuke? :D
No Xist, I think the right term for that is "dead" ;)
I agree though with the others, using a turbo to drive the alternator would be a fun project, but not really useful. |
We have a lossey vacuum because of the need to restrict power on partial load. The name for that (pumping loss) is telling. The vacuum is created by the engine drawing air in against the vacuum. The "work" therefore is already happening. It is controlled by air friction over the edges of the throttle plate. It makes no difference whether you do that restriction by a throttle plate or a small turbine, as long as the restriction matches the need. But the turbine could drive an alternator - for free, basically. The vacuum traditionally gets used for other purposes as well - to power brakes and there have been cars where it was even used to power the windshield wipers. When you wiped the windows on those while idling the engine would rev up slightly for the extra air flowing in. You can hold your hand ahead of the carburetor but you cannot sense the vacuum behind the throttle plate. That can be as low as 20% of atmospheric pressure at idle. Which you can easily monitor if you have an OBDII device... I saw it go down to 20% on my Insight, I guess that is a normal value at idle. Then again, even if you manage to control the turbine well enough to double as a throttle valve it will still be hard to maintain the power needed for the 12V system. It would need all the work done with a regular alternator delete, and compared to that it would be hard to make a ROI on the extra parts for the turbine. Technologically possible, but economically feasible just for special cases. |
One problem with the harvesting turbine on intake would be a drop in intake air temp.
If you draw a vacuum the temperature drops. Some of the heat loss is overcome by the friction, but if you take that away with a turbine then the air temp would drop more - quite some in fact. This may reduce the combustion efficiency. Would be good combined with a WAI though :) |
I recall one dyno we did where turning on all the electricals sapped some 5 horses (on a small car) from the wheels. But that's everything on except AC... which you won't be doing a lot of. Still... I don't think it's worth it. |
IIRC the on-board electric power generation on commercial aircraft while they're flying is provided by stators/magnetoes driven by the turbines. Sure it's not the same as a turbocharger, but might give you some inspiration.
