EcoModder.com
-   The Unicorn Corral (https://ecomodder.com/forum/unicorn-corral.html)
-   -   The TURBONATOR. YES? Or NO? (https://ecomodder.com/forum/showthread.php/turbonator-yes-no-23039.html)
Chisel 08-23-2012 11:37 AM
I keep hearing mixed views about the turbonator. I had a 92 golf that someone had put a turbonator in the piping. And for a 1.8, it was powerful, but still seen pretty excellent economy, has anyone ever tested it properly? Beneficial? Or a hinderance? :confused:
mcrews 08-23-2012 12:06 PM
Try searching....we've beat this horse....I mean unicorn to death
gone-ot 08-23-2012 05:35 PM
...Unicorn field fodder for sure!
Chisel 08-24-2012 02:06 AM
So it's bogus then?
niky 08-24-2012 02:34 AM
It'll put out enough air to give you boost.
At idle.
These types of things are typically worth around one psi or so of boost at low rpms. Enough to give you maybe 1 hp or so at low rpm, but nothing more. And nothing you will notice on a dragstrip or a road course timesheet. That's a result you could obtain with an intake or an air filter that won't draw current from the battery like crazy, overheat and leave charred wiring all over your engine bay.
Chisel 08-24-2012 02:50 AM
Oh. The on that the golf had wasn't electric. I think it operated on a small roller bearing. It was a clamped in unit that just spun faster the more airflow going through it.
mcrews 08-24-2012 04:03 AM
Originally Posted by Chisel (Post 323521)
So it's bogus then?
quess you didnt do a search to try to educate yourself????????
turbonator - Google Search
ChazInMT 08-24-2012 10:40 AM
http://i47.tinypic.com/3463kwl.jpg
Nuff Said
SecondWind 08-24-2012 10:48 AM
Mythbusters Turbonator
