Twin Bike Sports Runabout
2 Attachment(s)
Engines synchronized by common distributor
Bikes already suck vs cars re payload moved/gallon. This twice as bad.
This is just for fun!
Yes, some method of de-clutching the inside wheel activated by the steering, perhaps electrical clutches on the rear wheels.;)
2 Attachment(s)
The closest to that I've seen were projects for wheelchair-accessible trikes, but those resorted to scooters instead of traditional motorcycles. But I'm not sure what had been done to keep the engines synchronized.
1 Attachment(s)
(Something like this:) |
Let 'em be "unsynchronized"- twin engine aircraft make no attempt to phase crankshafts; matching rpm is sufficient.
Twin engine aircraft don't drive a single wheel, and drive, instead, a fluid. In addition, to provide for rpm differential to aid in turns, the two aircraft engines have to be able to operate separately. Again, twin engines provide limp home capability. On the other hand, I believe some twin engine aircraft DO mechanically join the two props, so that one engine can turn both, if the other goes out.
I don't want the engines to phase in and out with each other. Those vibrations would be far less pleasing than eight evenly spaced firings. |
