ultimate mod - electric
try it, you'll like it!
If you are contemplating an engine swap, or have a swift with a dead motor... go electric! I finished one in March, and am really having a blast with it. I used a DC motor and 12 x 8v golf cart batteries. range is 40 miles-ish at average in-town speed around 35mph or so... This setup has almost identical peak HP and a little more torque than the original swift 4 cyl. It drives almost identical with regard to acceleration and top speed. I went with all new DC motor and 'stuff' including lead-acid batteries. Material cost was right at $8k. If you go crazy with AC motor and Lithium batteries you can have a hot autocrosser, but end up spending closer to $20k. Anyway, if you're curious, I have documented the whole build process at Homepage - EnviroKarma.org |
Welcome to EM!
You're preaching to the choir, as it were -- there are several folks here who have also done this! I've never heard of 8v batteries before, though... |
congrats on the install, very clean! Just another excuse for me to buy one and convert it!
also considering removal of rear mirrors and going with video, but I'm not sure its legal... |
Have you tried 12V marine deep cycle batteries?
Traction motor batteries tend to be the heaviest of deep cycle batteries and they tend to come in 2 volt, 6 volt, 8 volt and 36 volt (the single large fork lift batteries), 12 volt deep cycle batteries might be able to handle high discharge, but they tend to still be a bit wimpy when it comes to handling continues high amp discharge.
