Ultra Gauge parasitic battery drain?
Just back home from travel for over two weeks. My kill-a-watt shows that the battery has drawn over 5.0 killowatts from the grid since I left. I have heard that the Ultra Gauge, before the latest update, had a parasitic draw. Is that my likely problem or is the explanation something else? Seems like a lot of power for a float charge.
EDIT: that's not 0.5 kwh but 5.0 kwh. Ouch. |
Yes, I can attest that both the UG and AutoMeter units that I initially bought had rather HUGE parasitic current loads which discharged the battery down to the point of "no start" on my 2009 Vibe during two week periods! And, that is *WHY* I bought a SGII.
yes the UG does have a parasitic draw if the correct power off/on settings are not set. For some vehicles there is no correct setting before the latest update. If i am not going to drive my car for 2 days i have learned to unplug it. I say this for the reason being shutting my car off friday at 230pm and if i try to start it on monday at 530am there is not enough juice to effectively turn the starter
This is completely off the subject... But my girlfriend insists my UG screen is one color, while I think it is another. Would you describe the UG writing as blue-ish or white?
(hoping I don't need to make an eye doctor appointment!) |
BTW, 5kwh over 17 days = 0.29412 kwh/day = 0.01226 per hour. That means I lost about 12.26 watts per hour, or that the draw on the system was 12.26 watts. Some portion of that was the Ultra Gauge, and 12+ watts seems high, but I guess some of it is the charger itself, its indicator lights, its fan, and etc... |
i dont know the details about the UG detection on your car so it is unknown to me whether or not you need the update |
I have an older UG (classic? not an EM). On my Silverado, it would occasionally stay on and draw down the battery. I got in the habit of waiting until the screen turned off before leaving my truck. Once the screen turned off, the drain was minimal.
On my Civic (I use the same UG that was in the truck) I have never seen it do this. |
Hello,
I know this is an old thread, but searching here didn't turn up further discussion. I had been hunting down a parasitic drain, and eventually found that fuse 12 (the OBD port) was sucking 20mA. I hadn't seen any figures above posted for current loss, but 20mA is not insignificant. A VW TSB (how I got the current flow, just calculated from voltage drop) for this issue states that in sleep mode the Jetta should be at 40mA or less, so under max allowable conditions the UG would be 50% of the current drain. I know there's a fix, just wanted to share. I was able to turn that on/off by unplugging the UG. Car had been off for a couple hours, so I imagine the UG would have no reason to be on. Anyway, love the gauge but don't want to have to ship it in or deal with it scanning each time i re-plug it in. |
