Ultra-gauge wiring diagram...
Didn't find anyone who's already accomplished this... ;)
Ultra-gauge... - Page 3 - Toyota Nation Forum : Toyota Car and Truck Forums |
Just so you know...you could probably put in a RJ45 (LAN/network connector) setup similar to the Scangauge II setup since there are only 8 wires in the wiring.
Chances are that you could even use the Scangauge cable if you pin that out and wire out the Ultragauge to accept it. :D Spare Scangauge cable fer $20 plus shipping... :( Buy Direct : Linear Logic - Home of the ScanGauge |
