Ultragauge + Scangauge on an obdii y cable
I just wanted to put this here to save another the trail and error I just went through.
I cut off a second obdii port from another civic and spliced it to my existing one. I confirmed that on a 1997 Civic you CANNOT run both gauges at the same time. I have read that others were successful doing this but it definitely doesn't work with this ecu. I'm pretty certain it's due to the K-line ISO 9141 protocol this car uses. I bet if your car uses a can-bus it would work. |
