Old 05-09-2019, 01:53 AM   #251 (permalink)
Custom User Title
Gasoline Fumes's Avatar
Nut Wagon - '91 Honda Civic Wagon DX
Wagons
90 day: 67.84 mpg (US)
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 - '00 Honda Insight
Gen-1 Insights
Currently working on sorting out the fuel system. I hadn't realized but the TSX motor has a returnless fuel system. The CVT Insight also has a returnless system (or at least, the return is in the tank) whereas the 5MT Insight has a return line from the fuel rail. Looks like I'm going to need an aftermarket fuel regulator and to re-plumb the lines.
You might want a larger fuel supply line anyway. I think it's only 6mm/0.25" on the Insight?
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
Ecky (05-09-2019)
Old 05-10-2019, 03:42 PM   #252 (permalink)
Gaptooth (retired) - '00 Honda Insight
Gen-1 Insights
90 day: 54.26 mpg (US)
Such Fit - '07 Honda Fit Sport
90 day: 41.27 mpg (US)
Connect - '15 Ford Transit Connect XL
90 day: 23.99 mpg (US)
Ksight - '00 Honda Insight
90 day: 43.36 mpg (US)
Ended up with an AEM fuel pressure regulator, connected to the stock fuel and return lines. From the regulator it's a "dead head" system to the rail. This keeps both the factory fuel pump, and also the engine's stock fuel rail, and fuel pressure is adjustable should I ever decide to go that route.
The Following 2 Users Say Thank You to Ecky For This Useful Post:
Daox (05-10-2019), niky (Today)
Old 05-21-2019, 08:14 PM   #253 (permalink)
Gen-1 Insights
The Following 3 Users Say Thank You to Ecky For This Useful Post:
fusion210 (05-22-2019), ME_Andy (05-21-2019), samwichse (05-22-2019)
Old 05-21-2019, 08:22 PM   #254 (permalink)
Gen-1 Insights
Still need to sort out:
-Have CEL for VTEC pressure
-My harness had no connector for rear O2 sensor
A/C wiring
-Coolant gauge - I moved the old sensor over, just needs a wire
-Shortening shifter cables so 6 and R clear
-Put speedo converter box in so I have working speedometer
-Cruise control wiring
-Alignment
As a side note, the transmission is 100% brand new inside, and it's a bit hard to shift. It has less than 2 miles on it, hoping everything went back together right and it just needs to wear in.
Daox (05-21-2019), roosterk0031 (05-21-2019)
Old 05-21-2019, 09:35 PM   #255 (permalink)
Last 3: 51.27 mpg (US)
Winter beater Metro - '00 Chevrolet Metro
90 day: 61.51 mpg (US)
Cool. Moving along. More than I can say for my projects!
Latest mods test: 15 mods = 15% MPG improvement: A-B test, 2007 Honda Civic 1.8L, 5-speed
Ecodriving test:
Manual vs. automatic transmission MPG showdown: Nissan Micra 1.6L
Old 05-21-2019, 10:02 PM   #256 (permalink)
NoD~'s Avatar
Frogger - '00 Honda Insight
90 day: 70.12 mpg (US)
Scooby Lue - '03 Subaru Forester X
90 day: 24.8 mpg (US)
I probably missed it, but what's the radiator plan? I couldn't imagine the stock Insight one is going to do well in a hot summer day with the upgrade, especially when you are feeling feisty!
Old 05-21-2019, 10:06 PM   #257 (permalink)
Gen-1 Insights
What I've heard from others is that it does fine. I'll find out, of course.
Old 05-22-2019, 11:01 PM   #258 (permalink)
Currently doing some future planning for my CRX HF when the motor eventually goes. I've got 320k on the clock, probably have another 150 before I spin a rod or something.
I'm looking into a k24 and there is plenty of varieties out there. Do you know what an insight gets apples to apples mpg In driving with a k24 versus OEM?
Old 05-23-2019, 05:51 AM   #259 (permalink)
Gen-1 Insights
Not yet!
With a CRX you're likely to need a large hood cutout, the engine bay isn't tall enough for a K series.
Old 05-23-2019, 07:26 AM   #260 (permalink)
Custom User Title
Wagons
Gen-1 Insights
Gen-1 Insights
Not yet!
It's barely tall enough for a 3-cyl Metro engine!
The Following 2 Users Say Thank You to Gasoline Fumes For This Useful Post:
Ecky (05-23-2019), MetroMPG (05-23-2019)
Copyright ©2000 - 2019, vBulletin Solutions Inc.
