06-29-2018, 01:00 PM
#21 (permalink)
I'll look into it!
The mounts are still a bummer, it will likely end up being more expensive overall.
06-29-2018, 01:12 PM
#23 (permalink)
Thalmaturge
06-29-2018, 01:13 PM
#24 (permalink)
$700 is a bit steep.
Short runners will probably affect low end torque too. Buuut it makes it a lot more feasible.
07-02-2018, 08:57 AM
#25 (permalink)
Originally Posted by Ecky
Trying to decide.
3.4 FD, stock 165/65r14 tire size
2180rpm @ 65mph
1680rpm @ 50mph
3.4 FD, common 185/65r14 tire size
2085rpm @ 65mph
1605rpm @ 50mph
4.105 FD, stock tire size
2635rpm @ 65mph
2025rpm @ 50mph
4.105 FD, 185 tire size
2520rpm @ 65mph
1949rpm @ 50mph
Honda Insight 1.0L gearing - 3.208 final drive
2350rpm @ 65mph
1810rpm @ 50mph
I really think a 3.4 FD is a good idea, but it adds considerable cost to the build. I suppose the 4.105 wouldn't be the end of the world if I moved to a larger diameter tire too.
Quoting myself here because I need to update this. Hybrid Racing's K series transmission guide had the wrong ratio for the 2012 Civic Si's 6th gear - it's actually a bit taller.
Looks like I'm not going to be able to get ahold of a 3.4 FD, no matter how much money I throw at it. The one person who makes these will only make them if there's a group buy-in, so 4.059 is the tallest I can reasonably get.
That said, with the new ratio, it looks like this:
2350rpm @ 65mph
1810rpm @ 50mph
Civic Si transmission + 4.059 FD
2556rpm @ 65mph
1966rpm @ 50mph
Civic Si transmission + 4.059 FD + 185/65r14 tires
2444rpm @ 65mph
1880rpm @ 50mph
^ To me that looks pretty reasonable. Ideally I'd have taller gearing to go with the bigger motor, but at least it's not significantly shorter.
In theory, if I could get the 3.4 FD and put on 185/65's though...
Civic Si transmission + 3.4 FD + 185/65r14 tires
2047rpm @ 65mph
1575rpm @ 50mph
What a dream. I might even be able to nearly match the 1.0's fuel economy with a 6th like that.
Here's this dream transmission, graphed again'st the Insight's stock ratios:
07-03-2018, 06:34 AM
#26 (permalink)
Looks like I'm getting the 3.4 final drive after all. After pestering him, the guy who makes them caved and ordered a run.
With gearing like that this really might not be un-ecomodding.
07-03-2018, 10:32 PM
#27 (permalink)
Cyborg ECU
That's the Si transmission with a 6 speed. Wow. Tall combination. With the 3.4 FD your RPM estimates are really low. My 3.25 FD, 0.710 5th, and 175/70-r15 wheels/tires turn the tach about 1770 rpms at 55mph.
07-10-2018, 04:03 PM
#28 (permalink)
Thoughts on K24 vs K20 fuel economy potential?
K24 is basically a stroked K20 - both have (approximately) the same cylinder bore. The K24 produces around 20% more torque, almost exactly the amount you'd expect based on the considerably longer stroke and correspondingly higher displacement.
All else being equal, I'd expect a motor with a longer stroke to provide better fuel economy (e.g. 2.0L vs 2.0L) due to better cylinder geometry. However, the K24 has more displacement. As long as I'm not needing to downshift when cruising, I expect that would work against me. A K20 will be running at higher load in the same gear, but its peak efficiency will also probably be at a higher RPM.
07-10-2018, 05:34 PM
#29 (permalink)
Do you have a torque/hp graph for both engines? That would help show what kind of loads you'll be at cruising.
07-10-2018, 06:36 PM
#30 (permalink)
Yep.
K24Z7 is ~170ft-lbs torque peak, ~205HP on paper, redline is 7000rpm.
K20Z3 is 139ft-lbs torque peak, ~197HP on paper, redline is 8000rpm.
Sample K24Z7:
Similar K24A2:
Sample K20Z3:
Similar K20A2:
Both motors have basically flat torque curves. The smaller motor would have a slightly shorter top gear (I doubt I'd bother switching that). With the Insight's stock tire size:
Stock engine - 1705rpm @ 50mph, 66 ft-lbs of torque and it cruises at approximately 50% load. So let's say it takes very roughly ~35 ft-lbs to cruise at 50.
K20 - 1680rpm @ 50mph, ~120ft-lbs torque, around 25-33% load
K24 - 1647rpm @ 50mph, ~140ft-lbs torque, around 24-28% load
Taller gearing, longer stroke, but lower load...
The Following 2 Users Say Thank You to Ecky For This Useful Post:
