Old 09-15-2017, 10:34 AM   #1 (permalink)
jackbauer's Avatar
Tesla Powered BMW E31 8 Series
So some of you might already know about my E31 conversion as it's been going on 3 years now! Currently running a Siemens 1pv5135 motor and DIY inverter and 6 speed manual gearbox. Has been running very well the last few months but with the Tesla components becoming available and my work on the open source control boards progressing nicely I've decided to convert the E31. Again.
I had originally thought to use the small high efficiency drive unit but decided to go all in and put in the Large rear unit for 450hp+
Going to be getting some help and the use of a workshop and vehicle lift for the drive unit install as it will need some serious work done to the rear subframe and boot floor. Once the drive unit is in then I can start putting some batteries into that nice big empty engine compartment. Should make quite a fun car and test bed for the open source control board. Stay tuned
Name:	2017-09-12 19.33.24.jpg
ID:	22678   Click image for larger version
ID:	22679   Click image for larger version
Name:	2017-06-13 14.40.09.jpg
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
The Following 4 Users Say Thank You to jackbauer For This Useful Post:
Daox (09-15-2017), MetroMPG (09-15-2017), oldtamiyaphile (09-15-2017), thingstodo (09-15-2017)
Old 09-15-2017, 10:42 AM   #2 (permalink)
JockoT's Avatar
All That Jazz - '06 Honda Jazz i-DSI S
90 day: 48.72 mpg (US)
Looking forward to following this build. Should work well.
People Think They Are Thinking When They Are Merely Rearranging Their Prejudices
Old 09-15-2017, 03:49 PM   #3 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Fun, fun!
Subscribed for for future updates.
Old 09-15-2017, 09:44 PM   #4 (permalink)
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
With all that power on tap ... are you going to put the EVTV Quaife limited slip differential into the Tesla Rear end or are you going to trust yourself to keep your pedal OFF the metal?
I'd go with the Quaife .. since I know my foot is heavy ...
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
The Following User Says Thank You to thingstodo For This Useful Post:
freebeard (09-18-2017)
Old 09-18-2017, 12:12 PM   #5 (permalink)
Are you going to use the same style mounting as BMW does with the rear suspension? Was thinking it would be kinda cool if you could build a cage to hold the power unit, then the cage would use the factory suspension mounts (Including the bushings) , you'd be able to drop the whole power assembly as a unit, make it easy to fiddle with. I have a E46, 3 series ,, assuming the E31 is similar?
Put double A-arms on the cage for the suspension and use the stock BMW hubs?
Cheers,,, cool project!
If it has a motor its worth playing with.......
