Underbody spoilers vs bellypan
Same as my post earlier today on spoilers vs full wheel skirts - would two or three spoilers mounted across a vehicle's frame work as well as a full bellypan?
I noted in the post below that if front air dams work to some degree why not put a couple more under the vehicle to reduce drag (but not vertical air dams but appropriately angled air deflectors.) ie at some distance behind the air dam I imagine turbulence increases due to the frame and drivetrain components. Would a spoiler help streamline the airflow under those components. http://ecomodder.com/forum/showthrea...ag-1783-2.html Quote:
From what I understand you can use this trick with decent results. This is similar to an arrangement I'm working on with my Jeep. You would probably need more then two or three for a car for it to work well. The big thing is getting them spaced/angled correctly to work optimally.
spoilers/ground clearance
I have no data for undercar multiple spoilers,so I'm worthless to you on that one.----------------- With respect to ground clearance,I would infer from the really low-drag concept-cars,that limiting ground clearance is good for mpg,even with cars which have completely smooth undersides.Active suspension is always involved,and lowering only occurs at speed,and never on surface streets or arterials.
