"underdrive" power steering pump?
I know, I can buy an underdrive crank pulley for about $130 for my car that will underdrive all my accessories. I'm not interested in shelling out that kind of dough for a mod that might give me 3-4 mpg on the highway.
I know some off road guys, (4x4 with big, near-flat tires) overdrive their power steering pump by altering the high pressure bypass valve in the pump. They want more help in maneuvering giant tires on steep boulders. I was curious if anyone knew of someone altering it in the other direction; to reduce the amount of assist. I'd be fine with about 25-50% of the assist I currently get. It would also reduce wheel turn with bump starting during a slight turn. (bump starting during a big turn or a slight turn at high speed is dangerous because of the sudden steering response!) |
I wonder if they make an electric power steering pump. Then somehow make it so it only runs below a certain road speed. Some cars have speed sensitive power steering anyway, since you only really need it going very slow.
They do make electric power steering pumps. A lot of hardcore autocross racers have them.
You have a fairly light car, you might be able to eliminate the P/S all together. If you run a tube from the "out" to the "in" on your rack and put a breather on the bypass tube, you can get pretty good steering with a power rack and no pump, this only works well on light cars. On my civic I have something similar done, and its actually barely noticeable. Its only a little tough when you're going really slow, but hardly anything that I would complain about. |
The Escort could possibly be retrofitted with a manual rack. That would permit you to forego power steering entirely. That'd eliminate weight, engine drag, and one more component to break.
Underdrive pulleys are a popular performance mod. However, many people have found that they need to add an overdrive pulley for the alternator when adding an UD pulley so it will keep the battery charged at idle. How much you would gain is hard to say.
As for the power steering delete, I don't know if I would want to try that. I have tried to EOC in my Escort, and even at about 40 mph the steering felt very heavy, probably too heavy for an emergency avoidance maneuver. I know this car is available without PS, but I believe a manual steering equipped car would have a much lower steering ratio (i.e. more turns lock to lock for less effort). FWIW, you can also get an electric water pump for some cars, another common performance mod. |
I've been wishy-washy between the two - replacement with an Escort Pony manual rack or just looping the lines together on mine. I called every junkyard in the area this morning and noone has a Pony - they're kind of rare.
I can get a remanufactured one for $350 - over 75% of the cost of the car! I do ok with the steering in EOC and I've been told it's easier if you bypass. I won't do an electric one - another thing that's very expensive. I just thought I might be able to keep some PS for convenience when the car's running and have it be closer to what it's like in EOC - that way I get used to the increased effort and if I do have to avoid something while coasting up to a red light (highly unlikely), I'm ready for what it'll take. I think next fall (when my official FE testing begins) I'll route the lines together and see how much FE gain I get, if it's worth it, etc. Thanks for all the input, guys!!! Matt |
So do you EOC in your Escort? I tried it once in mine (even though I am told it shouldn't be done with an automatic). The brakes were scary, I had almost no stopping power.
From past experience - a PS rack steers much easier if you can get most of the fluid out of it. This is pretty easy to do. Simply diconnect the hoses, put them into a bucket and go lock to lock several times. Then do your "bypass hose" trick to keep dirt out of the system. If you can get most of the fluid out of the cylinders, you won't have to push it back and forth in manual mode.
The best way to find a PS underdrive pulley would be a tour of the junkyard. You'll find that most Ford vehicles use the same PS pump. Taurus, Explorer, Thunderbird, F series, etc. If you can snag yourself a pump with a pulley that is 20 to 50% larger, you'll be set. Lowering the bypass pressure will lower the pressure seen by the pump. Mechanically, the more efficient route is to slow it down so that it makes less pressure in the first place, rather than spilling it off. |
2 Attachment(s)
I know this is a few years late but thought to add it anyway. Yes you can reduce the load that the power steering has on the engine. Simply remove the spring called the "flow control spring", shorten it and put everything back together. First you need to drain the power steering fluid to stop spills. On mine I shortened the spring so that power steering has only enough effect to make parking a bit easier than without power steering. I did a full power steering delete on my previous pickup with loop, but someone needed the vehicle. :( Haven't seen it since. With this one I cut the spring shorter until the plunger sits about 3mm above the opening where it circulates back. That gives just enough power steering to make turning easy enough so that you don't have to gym for it. They do sell equivalent springs at some hardware shops, so maybe buy one the same as one in pump and cut it. Of course it will use a bit more fuel than a full power steering delete, but driving is just more pleasant this way. It's also much more fuel efficient than doing nothing, and much easier and cheaper than full power steering delete. Attached is some diagrams of pumps. The spring is nr.7 on first and nr.8 on second one. I found mine under the high pressure pipe leaving the pump. Jan |
