Old 10-08-2008, 12:51 PM   #1 (permalink)
93 Metro Streamliner
AeroMetro - '93 Geo Metro
Rubber ground skirt
I have noticed some of you are using lawn edging.
Many years ago, JC Whitney used to sell rubber ground skirt material specifically designed for the purpose, available in 4 and 6 inch widths. Does anyone know if and where this is available now?
Old 10-08-2008, 01:39 PM   #2 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
I can't help you with the rubber skirt material, but I'd like to strongly recommend coroplast. This morning I parked a little too close to a cement parking curb. The airdam bent and when I pulled back it took its original shape back. It really holds up well.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 10-08-2008, 03:26 PM   #3 (permalink)
That VX guy!
TomO's Avatar
The VX - '92 Honda Civic VX
Send a message via AIM to TomO Send a message via Yahoo to TomO
If you're set on using rubber, you can go here: Racing Rubber Lip and try using the lip for a 88-91 Civic, it's about the closest shape to your Geo.
EDIT: you can also look here: Sheet Rubber for ideas.
I have emailed the owner of RubberRacingLip.com and invited him over to EM to offer his product to us as well as planted the idea of making rubber side skirts. Let's hope he makes it here.
Old 10-08-2008, 05:04 PM   #4 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 Scion xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '10 Honda Insight EX
90 day: 51.5 mpg (US)
For those that like to DIY, you can also use the heavy duty rubber mudflaps that are used on Tractor Trailers. You can cut them to the exact height you need using the natural length of the mudflap. One mudflap should serve on complete side of our cars in two pieces, plus each one is around $2-$3 dollars.
Their heavy, so shipping may make them a bit expensive, but if you live in a large city there should be a truck stop or repair center that stocks them, they are required by DOT.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 10-12-2008, 05:31 PM   #5 (permalink)
Skirt material...
There is a flower garden edging material...made out of heavy vinyl...Which I have found to be most useful for skirting / air dams on cars. It is sold in hardware stores ( which is where I discovered it ) and (perhaps) in the garden section of major discount stores.
Old 01-10-2009, 02:28 AM   #6 (permalink)
Diamond Lok
Stiff plastic though
The Following User Says Thank You to winkosmosis For This Useful Post:
minAirForce (05-17-2011)
Old 01-10-2009, 03:39 AM   #7 (permalink)
NightKnight
NachtRitter's Avatar
RippinRoo - '05 Subaru Legacy Wagon 2.5 GT
Subaru
90 day: 21.16 mpg (US)
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 53.91 mpg (US)
Olga - '03 Volkswagen Jetta Wagon
90 day: 46.24 mpg (US)
TomO - Thanks for the links!
I was interested in that kind of thing too... but for side skirts as well as air dams... Would like something that holds its shape on the freeway, but can handle getting crunched by a speed bump...
Old 01-10-2009, 02:56 PM   #8 (permalink)
Check this out MX-5 Miata Forum - My Home Depot lips
Home Depot has some foam garage door seals that can be used for skirts, and they're flexible. There is also discussion in that thread about the Diamond Lok skirts.
Old 01-10-2009, 05:36 PM   #9 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
I use ripstop conveyor belting. It ain't cheap and a bear to work, but it is indestructible. You can get greedy on clearance because it is so tough.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 08-10-2009, 07:38 PM   #10 (permalink)
Stickers - '91 Ford Tempo GL
Send a message via AIM to Hermie Send a message via MSN to Hermie Send a message via Yahoo to Hermie
Bump for ideas. I'm looking around for some rubber to work with for my air dam and side skirts.
Rear Wheel Skirt using water heater drain pan cfg83 Aerodynamics 45 02-20-2012 02:08 AM
DIY Rubber Front Wheel Skirts newtonsfirstlaw DIY / How-to 32 05-19-2011 07:45 AM
Front Fender/Wheel Skirt Idea.... justpassntime Aerodynamics 23 05-17-2011 01:44 PM
Mini-skirts, THE only Side Skirt for small SUVs Xringer Aerodynamics 29 09-19-2008 12:33 PM
Dream Wheel Skirt. Am I Crazy? 2003protege Aerodynamics 7 05-21-2008 01:40 PM
