EcoModder.com
-   Saving@Home (https://ecomodder.com/forum/saving-home.html)
-   -   ups battery (https://ecomodder.com/forum/showthread.php/ups-battery-10413.html)
bgd73 09-30-2009 10:09 PM
ups battery
My pc in my locale has to have a UPS just to attempt realistic chores for any amount of time without having a mental snap over sudden shutdowns.. most in the north would agree, brown outs galore, and when storms come down it is no height to them, pc death imminent. Anyway, the excuse for paying alot for a home pc backup ups is a good one.
and I found something interesting after seeking a new battery, it has been 6 years.
going by dimensions, the battery can be upgraded in my apc 500-es, by about 2000 mah. 1 dollar more than the original. this saves another dead battery needing a place to get recycled or dumped, as it adds time. A thought to ponder in the ecomod realm, batteries are getting better for everything.
Christ 10-01-2009 12:00 AM
The mAh rating doesn't necessarily add life to the battery, it just adds time to the discharge rate.
If you're interested in using a larger battery, and don't care what the setup actually looks like, you can use a the internals from any UPS and hook them up to just about any battery you want, put it in a project enclosure, etc...
I had a UPS that I built from a couple car batteries and an invertor that allowed my computer to run for several hours before it went too dead.
Back when I cared about computers... Not so much into them anymore.
wikityler 10-02-2009 03:02 AM
Make note that a discharged car battery can overload the UPS charging circuit when the power is restored.
Christ 10-02-2009 03:03 AM
How, exactly? The UPS charger (in mine, anyway) only charged like 3 amps at 12V... I'm not sure how a battery can overload a charger, when the charger is outputting it's max power any time it's charging.
wikityler 10-02-2009 03:24 AM
"Overload" wasn't the best word to use. What I meant was: The charing circuit may provide insufficient current to charge a dead battery in a practical amount of time. Also the circuit wasn't intended to operate at full capacity for extended periods of time, as this isn't a condition that occurs when using the OEM battery.
Christ 10-02-2009 03:31 AM
Ah - the charging circuit is usually equipped with thermal protection, so that if it gets into a dangerous condition, it stops charging.
I never drained the batteries while using mine, but it never took more than a day to recharge completely to the point that the UPS' charger would stop outputting voltage.
Of course, the idea of a UPS isn't to allow you to keep working, it's to provide you with a surge buffer and keep your machines running (hopefully) until the power comes back online, or until you can get a real backup system running, or to provide you enough time to finish what you were doing, and shut down/turn off safely.
Clev 10-02-2009 10:28 AM
My older APC unit has a small fan that comes on when charging/discharging. I would feel more comfortable about using that to recharge large batteries.
Ryland 10-02-2009 11:41 AM
The sealed lead acid batteries that are in UPS systems are in there because they ship well and you can forget about them until the fail and you have to buy new, a regular flooded deep cycle battery should last longer, be cheaper to buy and as it gets older you can top off the water instead of buying a new battery, add a desulphater to it and it should last 20 years.
Clev 10-02-2009 12:38 PM
I'd prefer an AGM battery. They are less likely to spray a fine acid mist over everything if they're somehow overcharged, and they'd last just as long in a UPS application.
Christ 10-02-2009 12:46 PM
If I still had mine, I'd probably replace the (long since dead) batteries with lithium variants. I used to have a source for "dead" laptop batteries, which I could get for free, and repair for very little money. (It's often only one or two dead cells, not the whole battery.)
NiHaoMike 10-02-2009 07:42 PM
Converting from 120v to 12v and back to 120v is not very efficient. Build your own UPS from a power inverter and an ATX power supply with active PFC. Find the B+ rail (and its ground) in the inverter and connect it to the ATX power supply right after the input rectifier through a diode. Then add two 470uF or more 200v capacitors to the input circuit to make it a voltage doubler. (If 240v or 208v input, use only one 330uF or more 400v capacitor from B+ to B-.) Finally, keep the battery on float charge at 13.8v.
If you have an ATX power supply that accepts 12v from a wall wart (such as the PicoPSU), it is even easier. Same for most network equipment, which often operate from 12v. Just keep the battery at 13.8v with a float charger that outputs more than all the loads.
The Atomic Ass 10-04-2009 03:55 AM
The UPS units I have used so far have been entirely incompatible with Lithium. They continuously charge the battery at 13+ volts, so as not to overcharge it, but so that the battery is always fully-charged.
Christ 10-04-2009 11:41 AM
Good point.. I'd have had to use some sort of extra circuitry and a charge switch to turn them off, so they didn't kill the lithium cells.
