Go Back   EcoModder Forum > AltModding > Saving@Home
Old 07-08-2010, 10:39 PM   #1 (permalink)
ragez0r's Avatar
Send a message via Yahoo to ragez0r
pooping bricks :)
ive learnt that some people cannot flush their toilet bowls by dumping a bucket of (gray)water in there.. so if youd like to save some water.. heres an idea... put 1 or 2 bricks inside your toilet water tank and voila
enjoy
Old 07-09-2010, 12:17 AM   #2 (permalink)
The Atomic Ass's Avatar
Overland - '24 Nissan Versa S 5MT
90 day: 40.29 mpg (US)
A shame mine simply would not flush like that. As it is, I've got the top off and I have to add more water to make it flush properly about half the time.
When I get my RV set up, whenever that will be, the gray water tank will be pumped directly into the toilet tank.
Old 07-09-2010, 12:38 AM   #3 (permalink)
JellyBeanDriver's Avatar
California had a rebate on low flow toilets. Put in a couple of Eco Drakes, 1.28 gal flush and the rebates paid for 3/4 the price of the toilets. Much better flushers than what I had before too.
Now there's actual semi-real testing done on toilets so you can get one that saves water AND still flushes well.
1992 Geo Metro, 1.0L 5spd, 435,000 miles on the original engine and trans!
- knuckles/hubs/brakes/13" wheels from a 2000 Metro
- running 175 70R13
- averaging 51.7 MPG, 56.9MPG best tank.
- self built MPGuino
- http://www.dschmidt.com/MPGuinoJBD.html
Old 07-09-2010, 12:50 AM   #4 (permalink)
ragez0r's Avatar
well since im in an appartment.. i have no intentions of changing my toilet bowl...
well it was just an idea
Old 07-09-2010, 12:55 AM   #5 (permalink)
Hmph. So it ain't just me.
Take that bucket o water and throw it in there straight down the chute- forget the tank. The extra inertia makes 'er go.
I make an effort to use a 5 qt ice cream pail of grey water whenever I remember to leave it in the sink to catch it.
Old 07-09-2010, 01:25 AM   #6 (permalink)
Bus - '94 Ford School Bus huge
Stupid - '01 Chevy Blazer LS
90 day: 21.38 mpg (US)
hawk - '00 Honda Superhawk
Thanks Frank,
I was wondering how the crapper they had wouldn't flush with gray water. My sis had a cabin without running water for a while and that is the way we flushed. I just couldn't figure out how it wasn't working for them.
On a side note, you can gain effectiveness in the pour-flush method if you don't directly hit the chute. It is called building a "head". Pouring off to the side will cause turbulence that will keep the water in the bowl longer, allowing it to fill and create a better siphon on the trap. Pouring directly in causes the trap flow to become turbulent (you dont want this) and it breaks up and pulls a poor siphon (doesn't flush well). good luck.
Old 07-09-2010, 03:05 AM   #7 (permalink)
ragez0r's Avatar
wow.. good tip on that one.. i hate seeing chunks of last nights dinner floating about
Old 07-09-2010, 05:40 AM   #8 (permalink)
Be careful if your putting a brick or two in the water tank, some water tanks are not held to the wall very securely. The weight of a couple of bricks could be enough to pull the screws from the wall(Had it happen once).
Another option is to use either a zip-lock bag, or an old plastic paint tin, filled with water, in the tank.
Old 07-09-2010, 07:46 AM   #9 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
I put bricks in the tank at my Mom's house many years back, but after 2-3 years they started to crumble (good material, eh?). I cleaned out the tank and put in 1 pint bottles filled with sand and water.
Old 07-09-2010, 01:00 PM   #10 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
I have a semi-automated graywater system at my house.
Used laundry water goes through a sandfilter/marshplants, gravity fed into a big rubbermaid trough, and then gets pumped to the toilet with a well pump on a pressure switch.
When you flush the toilet, pressurized water starts pumping into it from the graywater tank.
It works great.
Read more at:
Ben's DIY Graywater System - EcoRenovator
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
