Urban Cabin
I recently tried to buy a house at tax sale in my old hometown. My goal was to do an experiment on living without utilities, or better said with minimal utilities, because I planned to use a natural gas space heater for winter heat. The house I tried to buy was within easy 10 minute biking distance of downtown and $350,000 condos. I really like my old hometown, even if it is somewhat run down, and if I could get a cheap house with no mortgage, I could probably retire soon.
I did not win the auction, someone else outbid me by $1000 and got the house for $6000. I did not want to pay that much for the house, it needed some work and even if in good condition, it was only worth 30k in that neighborhood. It was probably better for everyone that I didn't get it, because I might have gone out in a blaze of Gran Torino glory. The neighborhood was actually not too bad, it was much better than my old neighborhood. The biggest problem I would face would be if city building code officials figured out I was living in a house with no water or power. I was hoping they had bigger problems to deal with and if I kept the house painted and the yard mowed that they wouldn't bug me. Here is the concept I wrote up, trying to figure out how I would change my lifestyle to live without utilities. These techniques are based on some wilderness backpacking skills, some urban backpacking skills (European vacation type backpacking), and living on a sailboat skills. I have a sailboat where I already use many of the techniques. I probably will not use this system, although I am still checking out the tax sales. I may focus on a rural area. I may just live on the sailboat for a while. Here are my notes. Urban Cabin Concept: buy a house at the tax sale and have all utilities turned off. Try changing lifestyle to allow for a no utility house. Systems that need to be accommodated: Rain barrel as water source install gutters all around roof, lead to barrels with overflow tubes to yard transfer water from outside barrels to inside barrels will it work in winter? Keep barrels in basement, try to fill many barrels in fall 6 barrels, 300 gallons maybe enough for 90 days of winter for one person insulate if necessary maybe 12V water pump to move water upstairs to kitchen and bathroom storage jugs or just fill jugs and carry upstairs drinking water use backpacking water filter and rainwater Washing clothes Use polyester and other synthetic fabric clothes, they dry quickly Wash small clothes in a washbasin in the evening, hang them up to dry overnight. Use a pail and plunger for large clothes. twist wring clothes to semi-dry, or get a wringer. Use a clothesline. Inside, hang a clothesline over a bathtub or shower so drips don't hurt anything. Outside, use a clothesline for larger wash days. Shower pressure shower from spray canister, pesticide sprayer type. Add hot water heated on stove, Either use thermometer or use the 50% room temp, 50% boiling water method. Go to gym for real showers Bathroom Sink: brushing teeth, shaving washbasin hot water from stove Use coffee type airpump thermos to hold hot water overnight use sink drain to dispose of water or put in toilet Kitchen Sink: washing dishes Use coffee type airpump thermos to hold hot water overnight washbasin hot water from stove use drain to dispose of water Toilet use rain barrel water to flush use grey water to flush pour from pail into toilet bowl Furnace, heat natural gas space heater, no electric load locate on lower floor in living room, near stairway use heavy curtains to block or allow heat flow upstairs or to other rooms If you are in living room, close curtains and keep warm If you go upstairs, open curtains to stairway to heat upstairs close doors to unused rooms. Air conditioning open windows at night 12V fans above bed? Too much electric use. Open windows on all sides of house, cross ventilation Refrigeration none, use a case or cabinet secure against vermin for food locking plastic containers dried vegetables dried food buy fresh food the day you cook it go out for ice cream Lighting 12V solar system 50W panel or 100W T105 batteries or marine deep discharge trolling batteries circuit breaker 12V LED lighting system use existing wiring? Lockout main breaker so no one can turn on the 120VAC power Use fuses and circuit breakers at battery keep loads very low. Under 5 amps check circuit for infinite resistance between power and ground, turn off if there is a connection Only power led lighting and computer If using inverter, connect direct to battery, not through house wiring Cover outlets with plates to prevent someone from plugging in 120VAC appliance. Vacuum cleaner Don't use a vacuum cleaner remove all carpet paint wood floor or add Pergo flooring sweep and damp rag to clean use throw rugs, take outside and shake them out Battery clocks Laptop computer running on 12V no tv charge computer and cell phone in car when driving (if you commute by car) Or use house 12V system Music Boombox connected to 12V Internet connection get outdoor antenna try to find free connection or get cell phone with plan blender maybe don't need one Fridge at first don't use a fridge If you want to get one, use chest freezer on dedicated inverter with temp controller possibly with arduino and thermistor, and relay to act as controller separate solar panel and batteries from house system? Maybe go with Engel cooler Stove Natural gas stove and oven Car Get job close enough to bicycle commute Live in city and use bus to go shopping Probably don't need a car in the city If you get one use hypermiling techniques |
My electric coop keeps jacking the monthly service fees, to the point where I'm about to tell em to stick it and I'll go off the grid. :mad: Most months the service fees and taxes are greater than the electricity charges! :mad:
Copyright ©2000 - 2022, vBulletin Solutions Inc.
