Use engine block heater to warm Catalyc converter ?
Would the Cat warm up faster if an engine block heater could be modified for it ?
Why not ? |
Cd -
I think it's a good idea but I also think the "scale" of temperatures is too wide. A Cat gets a lot hotter than a block heater. But I could be totally wrong. CarloSW2 |
Engine block heaters weren't designed to operate in free air, but immersed in coolant inside the engine block.
That being said, a properly installed block heater would still fire off your cat sooner. After all, waste heat energy is being shoved out the exhaust, that would have otherwise gone to heat up the engine block. How much sooner?... Eh. Tempted to say that you'd shave a few seconds off the cat's warm-up time. |
( In fact, on my first trip to Canada I saw all these cars with electrical wires hanging out the grilles and thought " Damn ! These Canadians have really got it together ! So many EVs ! :D ) |
How long does it take for the cat to light off?
Heating it wouldn't save any fuel... just cut emissions for a minute or so. The heated O2 sensor is what helps fe and emissions the most. |
Cd -
CarloSW2 |
C'mon its Earth Day :thumbup: |
So we need a heater for the O2 sensor eh ?
