used radiator ?
my radiator is covered of rock impacts like the more bright spot on this one
Avertissement de redirection i want to know if that affect the coolant temp? because if yes a can change my radiator and be more grill block and save more gas:D |
It reduces the radiator's ability to cool but if you're going to block it off anyway, I wouldn't worry about it. Let the temp gauge be your guide.
If you want to fix it there are such things as fin combs which are tools for straightening bent fins. Or if you are very patient and don't mind tedious work, you can straighten fins with a pair of small screwdrivers or knives. |
normal wear
You should see my echo's radiator !
http://img843.imageshack.us/img843/7681/nobumper.jpg The upper part is fairly "clean". The bottom section is plugged and that is where all the incoming air cools the radiator. With my partial lower grille block, the cooling is working as it should, but I do have a feeling that it would be more efficient if the fins were in good shape. If you want my opinion, keep your original radiator and save your money. |
Am I seeing that right? Not fin damage but stuff?... you should be able to clean that out with a shop vac and if not, a garden hose and/or an air hose from the back side (watch the pressure!!!)
You might be a good candidate for the ol' window screen over the radiator trick.
i will just try to clean it but the problem is in the summer i can not be more then 20% grill block or the fan starts regularly (yes i hear my fan:D ) |
Try a hair brush for the debris, A bondo spreader (body filler) will do a decent job on straightening the fins, without any danger of piercing the coolant tubes.
That being said, making your radiator work better could actually reduce your mileage in cold weather. If you do not climb mountains or haul heavy loads, both of which will test the capacity of your radiator then you might just leave it alone. Most radiators are getting tired at 10 years age, so consider that and price a new one if it is older than a decade. The tubes slowly clog up with gunk, just like some people's hearts and the max capacity to remove heat slowly declines. As you get close to the end of the life of the radiator the coolant coming out in the bottom hose becomes progressively more hot, until you reach the point where it can no longer keep your engine cool enough. The period of time just before failure can actually increase your fuel mileage. Why? Coolant exiting the radiator enters the running engine. The colder that coolant (new radiator versus old radiator) the more heat that same coolant will absorb from your engine. In some cases the difference can be 60+ degrees. Less heat removed from the engine means less heat lost from the fuel and more heat available for useful work. Especially in winter. regards Mech |
Remove the radiator and spray it with high pressure water from the back.
Watch it- a hose with good pressure can lay those fins right down. |
