EcoModder.com
-   Hypermiling / EcoDriver's Ed (https://ecomodder.com/forum/hypermiling-ecodrivers-ed.html)
-   -   Using E85 in TDi VW (https://ecomodder.com/forum/showthread.php/using-e85-tdi-vw-10104.html)
ucftabletennis 09-10-2009 10:34 AM
Using E85 in TDi VW
Does anyone know if you can pump E85 Ethanol fuel into a diesel motor, specifically a VW Golf 1.9 TDi? I live in Orlando and would love to pump B20 or B100 into it regularly, but stations are limited. I do however have access to E85 easier and would love to use it if it is safe.
Thoughts, suggestions?
Thanks.
dcb 09-10-2009 11:35 AM
dunno, here is a diesel that runs ethanol,
Scania’s Ethanol Diesel-Engine, Runs On Biodiesel Too : Gas 2.0
it has more compression and bigger injectors and probably numerous other tweaks.
dieselescort 09-10-2009 12:38 PM
Nononononono please don't do that! You'll trash your engine. Some people with old Mercedes diesels have used 85% veggie oil and 15% gasoline premixed, but this is not recommended. The TDI injection pump and seals are already sensitive to excess methanol and water from homemade biodiesel. Ethanol is a big no no.
ucftabletennis 09-10-2009 04:23 PM
What about MPG's?
Will your vehicle obtain better MPG's by using Biodiesel or even straight vegetable oil, rather than running on regular diesel??
dieselescort 09-10-2009 04:34 PM
Most people agree that there's not too much difference in MPG for biodiesel or petrol diesel. Biodiesel has slightly less BTUs, but has higher cetane, and additionally is a better lubricant so your engine will run quieter and smoother. Petroleum based diesel has more BTUs but lower cetane and crappy lubricity (unless you use additives, or blend biodiesel).
HTH!
