Using a JET Performance 67029 - JET V-Force Plus
Anybody have any experience with these? My FE Corolla is not OBDII but it says this can work on my years.?
JET Performance 67029 - JET V-Force Plus Details http://www.jegs.com/i/JET+Performanc...67029/10002/-1 Toyota/Scion V-FORCE PLUS - The JET V-Force Plus features the same power tuning technology found in JET's performance modules/programmers. The JET V-Force Plus is an inline tuning device that uses a microprocessor to optimize ignition spark advance and recalibrate the fuel maps for improved horsepower, torque, acceleration, and throttle response. The face of the V-Force Plus features backlit LCD display with built in dimmer. In addition the JET V-Force Plus allows the user to select from 14 different monitoring screens. This includes Throttle Position, Mass Air Flow, Manifold Pressure, Fuel Economy and Air/Fuel Ratio. Works great with other aftermarket upgrades including exhaust, intake, mass air, etc Improve horsepower and throttle response Optimized ignition advance curves Extensive recalibration of fuel maps 14 different monitoring screens Ability to add oxygen sensor hook up for additional monitoring Multiple ways to mount LCD included |
it basically is a scangaugeII( with a resistor)or capacitor) to override the ECU. It's doest allow you to make adjustments...i don't believe.
I would google it and see if others are using it and posting results. |
I wonder how it performs, I been reading up on it all night!
