EcoModder.com
-   Instrumentation (https://ecomodder.com/forum/instrumentation.html)
-   -   Using MAP Sensor Voltage to Monitor Engine Load (https://ecomodder.com/forum/showthread.php/using-map-sensor-voltage-monitor-engine-load-30459.html)
three6t 11-10-2014 12:06 PM
Hello there
I am an electronics guy and vacuum gauges are hard to find where i live, I have a voltmeter i managed to connect a voltmeter to MAP sensor which measures pressure.
Can i use this as an experiment too monitor engine load (pressure is proportional to vacuum) and thats what vacuum gauges do, if i keep an eye on MAP voltage on the fly would it help me to drive engine at minimum load and in that way i could get fuel savings without spending NOTHING at all. Is it a viable IDEA ? if it works i could buy a bluetooth voltmeter and write an application on my mobile phone which has a gps to at least calculate instant load vs speed which i thing would directly relate to MPG. Please give your valuable feedback if i should take this path as this could lead to a very very economical solution to boost mpg, I THINK imho but what do u think??
Bil:turtle:
dirtydave 11-10-2014 12:20 PM
Do you have an android phone?
You should get a obd2 Bluetooth dongle and torque app.
three6t 11-10-2014 12:36 PM
I tried one Dongle but it did not work
I tried one dongle it did not work because the dongles does not provide a wide range of interfaces, my car has KWP2000 and probably would get working on Scanguage but its expensive to import here
Daox 11-10-2014 01:27 PM
Yes, that should work just fine.
