V-12 diesel engine
AN OPERATIONAL V-12 DIESEL ENGINE THAT FITS IN THE PALM OF YOUR HAND.
This is not CNC technology; this guy made everything at home on his lathe and drill press. Took 1220 hours (a year and a half?) to make the 261 pieces. Note the end-loaded crankshaft into the block (like an Offy), 12 individual cylinder heads, TINY rods and pistons, dual "underhead" cams with pushrods to rockers in the heads. And, he did break-in runs using an electric drill driving the crankshaft. The world's tiniest V12 engine. |
Generator for a hybrid
I wonder if you put 4 of these together if you would be able to charge a hybrid battery at a more efficient rate of less fuel.:D |
Highly unlikely as it's efficiency will be quite low. It also has no lubrication or cooling systems. It is just a work of art made by a really talented machinist.
Simon |
this looks more like it's powered by air :rolleyes:
Still cool. |
